- Mute
- Permalink
- Report
I want to activate the folder(Waterline). But I can not get its name. How do I activate it?
IF entity_exists($entity("Featureset","")) {
ACTIVATE FOLDER ${dirname(pathname($entity("Featureset","")))}
Rafael Sansão
OptiNC - www.optinc.tech
Thank you. No error. But it doesn't work properly. I print it out and the path is not what I want. See the picture below.
string $p=dirname(pathname($entity("Featureset","")))
print $p
I tried this,
string $p=pathname($entity("Featureset",""))
print $p
and got "Featureset\FCS-24MM-DIA-M16-REG". Still not right.
The active hole feature set must be inside the folder. Looking at the image you uploaded, it is out of the folder.
Rafael Sansão
Here you go
DIALOGS MESSAGE OFF
DIALOGS ERROR OFF
STRING LIST folders = get_folders('FeatureSet')
INT idx = INPUT CHOICE folders "Pick a folder"
ACTIVATE FOLDER ${folders[idx]}
DIALOGS MESSAGE ON
DIALOGS ERROR ON
Yes. You were right. The feature set is out of the folder. Thank you so much!
