Feature Hole Colour
Feature Hole Colour
evo80
Message 1 of 11
Feature Hole Colour
evo80
Good Day,
Does anyone know why my holes are not colouring the same as the model colour, in fact when I edit the colour in the feature set properties the colour edit fails also.Screenshot (727).png
Replies (10)
Message 2 of 11
icse
That's interesting. There is a very recent topic where someone was unable to edit the color of a featureset with that command
edit featureset ; colour 1 1 1
Which normally should work. Both the command and the automatic color detection work completely fine on my end.
Maybe it's some kind of hardware issue or a graphics driver setting? Can you test it on another PC or upload the project?
What hardware do you use and wich version of PowerMill?
Message 3 of 11
evo80
I'm using,
Autodesk PowerMill Ultimate 2027
Version: 2027.0.0.2027004
Build Date: Fri Mar 20 16:08:54 UTC 2026
Status: Full Release
Processor Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz (3.60 GHz)
Installed RAM 32.0 GB (31.8 GB usable)
Graphics card NVIDIA Quadro P4000 (8 GB)
Intel(R) UHD Graphics 630 (128 MB)
Message 4 of 11
evo80
Ok, So use model colour for holes was unchecked, all is now fine.
However I have noticed something which seems to be unique to PM2027, when I click on a surface patch it fails to select, random patches select instead . This isn't the case with PM2026, anyone else noticing this with PM2027?
Message 5 of 11
icse
That's odd... i can't reproduce the error. I use the exact same PowerMill version. Latest Drivers installed. Ryzen 7 5800, RTX3070.
Do you get any error message? Or does just the color not apply to the featureset?
Message 6 of 11
evo80
@icse , see my message 4, the "Use model colour for holes" checkbox was unchecked, when checked the hole featureset behaves correctly.
Message 7 of 11
icse
oh trough you had that checked😅
but anyway this command should have worked to change the color of the featureset regardless if the option is checked or not:
Message 8 of 11
evo80
You're right, I just unchecked "Use model colour for holes" to check and now the holes colour correctly when I edit the colour, that is proper weird because it failed before or maybe I'm going mad! 🤔
Message 9 of 11
icse
Theres a bug for sure... For me its now the other way around, no matter what settings i use my holes always get the model color😂
Message 10 of 11
lauri_barnhart
Hello @evo80, thanks for posting in the community!
Did the information provided by icse help?
If yes, please mark the reply as the accepted solution.
This helps other community user find a solution to similar problems.
If you still require support, please post an update so we can assist you further.
Best,
Lauri | Community Manager
Let us know how we did on Trustpilot.
Message 11 of 11
lauri_barnhart
Hello, @evo80,
We are sorry to hear that you are still experiencing issues. We would like to suggest contacting Support for further assistance. They can help determine a possible workaround or if this is a bug, it can be reported to the appropriate team for triaging. You can always use the Autodesk Assistant on the support page to find answers or contact support.
Thank you for being a part of the community!
