Export tools to Fusion 360
Hi Everyone,
I thought I would share something I've worked on earlier this year. With Fusion being available through PowerMill since few years already, the request from users to be able to transfer data to Fusion has become more and more common. In an attempt to ease the use of both, I've written a plugin that allows a PowerMill user to export the tools loaded within the current project to Fusion. This will transfer the cutting geometry, the shank and Holder of each tool and match them with their corresponding type within Fusion. Cutting parameters from the General preset will also be transferred over if that interest anyone.
FYI, this is a plugin, so simply close PowerMill, run the installer and once you reopen the software you should get a message saying a new plugin was discovered. From there, within the vertical plugin window you should have access to this new tool.
Hope you find it useful!
Michael
Michael Grenier
Senior Solution Engineer
