Export tools to Fusion 360
michael.grenier4GVTU
Autodesk Autodesk
Message 1 of 37
Hi Everyone,
I thought I would share something I've worked on earlier this year.  With Fusion being available through PowerMill since few years already, the request from users to be able to transfer data to Fusion has become more and more common.  In an attempt to ease the use of both, I've written a plugin that allows a PowerMill user to export the tools loaded within the current project to Fusion.  This will transfer the cutting geometry, the shank and Holder of each tool and match them with their corresponding type within Fusion.  Cutting parameters from the General preset will also be transferred over if that interest anyone.
FYI, this is a plugin, so simply close PowerMill, run the installer and once you reopen the software you should get a message saying a new plugin was discovered.  From there, within the vertical plugin window you should have access to this new tool.
Hope you find it useful!
Michael
Michael Grenier
Senior Solution Engineer
Replies (36)
Message 21 of 37
rob_carri
Good morning,
@michael.grenier4GVTU  in what format do you export? I am looking for an excel export of all the components of the tool and conditions. it's possible?
Message 22 of 37
It's exporting a JSON file in the format of what Fusion uses to store it's tool database.  I don't see why exporting an excel spreadsheet instead of a JSON file would not be possible, but it would require a completely different output type which means there is about half of the plugin that would have to be re-written in this case but it's definitely possible to be done.
Michael
Michael Grenier
Message 23 of 37
nubrandao
My powermill 2024 Crash everytime i try to generate tool, whats is wrong?
Message 24 of 37
VitorMartinsAugusto
Check the file path (keep it simple).
Check the Regional Settings and try UK settings and/or "." as the decimal symbol.
Message 25 of 37
nubrandao
i instaled last version. works if i export do local like c:\
export direct to fusion crash
the problem now is that it gives an error importing the file in fusion
it only works with simple tool created by and (tool+shank+holder)
seems to give error because of the geometry of tool, tolerance or data speed/feed
Message 26 of 37
Can you share your original tool database along with the json file you are generating?
Michael
Michael Grenier
Message 27 of 37
nubrandao
as soon i arrive the company i share it
Message 28 of 37
nubrandao
solved changed my windows to english
Message 29 of 37
nubrandao
The problema mas the 'decimal' Changed from "," to "." In regional setings
Message 30 of 37
todd.murphy8YH67
now can we get the reverse as well HAHA😁
Message 31 of 37
Erjstaton
Observer
Observer
@michael.grenier4GVTU I am struggling to import a json file into Fusion. I have been provided the json file from a customers exported PowerMill database, then I go to fusion tool library, right click "Local" > Import Libraries > select the json file and then get an error message "Failed to import tool library. Contact the vendor that supplied the file.". Are you able to support on this? Thanks in advance!
Message 32 of 37
nubrandao
You can't import form tools from powermill
Message 33 of 37
it would be interesting to get the json file you are trying to import in Fusion to see where the problem is coming from.
Michael Grenier
Message 34 of 37
nubrandao
Tomorrow I will share, going to share form tools ok?
Message 35 of 37
jan_navratilJZD5N
Im trying to use this addin in 2024/11 but it seams that it does not work anymore, still getting error during the import into the Fusion that it failed.
Is there any newer version please? Anyone using this addin in 2024?
Jan
Message 36 of 37
It's probably one of the tool type that is not imported correctly.  You can try one type (not one tool) at a time to narrow down which one causes the problem.  But as stated before, FORM and ROUTING tools are not supported at this moment so you want to make sure none of them are part of what you are trying to transfer over.
Michael Grenier
Message 37 of 37
jan_navratilJZD5N
thank you for the comment !
Jan
