I appreciate your response, and I have thought about creating templates/strategies for the different cycles, but it doesn't solve the main issue for my users. Occasionally a user will run the wrong drilling method on a feature set. Instead of deleting all of the toolpaths and running the correct drilling method, they will recycle the incorrect toolpaths, change the cycle, and re-calculate the toolpath. We use Cycle 1 for ball drilling and cycle 2 for flat bottom drilling. If a user accidentally runs the ball drilling method on a flat-bottom hole, all they need to do is change the cycle of 1 toolpath from cycle 1 to cycle 2, instead of re-creating all of the toolpaths with the correct drilling method.
Again, I thought there was a way to edit these menus in previous versions of PowerMill. Maybe there no longer is. Could someone from @Anonymous chime in and put this to bed? I'm not looking to add cycles, just want to add a description of what the cycles are used for.
Cycle 1 - Ball Drill
Cycle 2 - Flat Bottom
Cycle 3 - Gundrill
etc.
