edit Drilling Cycle Type menu
cfastNJWK6
Advisor Advisor
Message 1 of 14
cfastNJWK6
Is there a way to edit the Cycle Type drop-down menu in the Drilling Form?  I would like to add descriptions to the vague extra cycles (Cycle 1, 2, 3, 4, 5 and Bore 3, 4, 5).
Accepted solutions (3)
Replies (13)
Message 2 of 14
Jonathan_Artiss19
Chris,
The way I see it, you have two options. A post-it note on the monitor, or a saved strategy in your "My Strategy" folder with the specific function as its saved name.
Jonathan Artiss
Senior Applications Engineer | DSI
Autodesk Expert Elite member
DSI, Design and Software International Autodesk Gold Partner
Message 3 of 14
cfastNJWK6
@Jonathan_Artiss19
I am trying to standardize things across 40+ powermill seats and 80+ powermill users.  A post-it note may work for me, but not everyone else.  I thought I saw someone change a list like this in the old Delcam forum.
For the most part I have hole drilling fairly well automated with 100's of different drilling methods.  The problem comes up when we have a job that wasn't designed by us and there isn't a drilling method associated with a certain type of hole geometry.  Then my Powermill users don't know what cycle 1, 2 or 3 is.
Message 4 of 14
minh.lenhat
For me, I do choose Cycle type then click Ok, then save toolpath as template and put a name for each.
Put all template in "Company Name" Folder, then all 80+ users just need all toolpaths inside your folder.
Le Nhat Minh
Senior Manufacturing Consultant
OneCAD Viet Nam Co., Ltd
Process Manufacturing
Message 5 of 14
cfastNJWK6
I appreciate your response, and I have thought about creating templates/strategies for the different cycles, but it doesn't solve the main issue for my users.  Occasionally a user will run the wrong drilling method on a feature set.  Instead of deleting all of the toolpaths and running the correct drilling method, they will recycle the incorrect toolpaths, change the cycle, and re-calculate the toolpath.  We use Cycle 1 for ball drilling and cycle 2 for flat bottom drilling.  If a user accidentally runs the ball drilling method on a flat-bottom hole, all they need to do is change the cycle of 1 toolpath from cycle 1 to cycle 2, instead of re-creating all of the toolpaths with the correct drilling method.
Again, I thought there was a way to edit these menus in previous versions of PowerMill.  Maybe there no longer is.  Could someone from @Anonymous  chime in and put this to bed?  I'm not looking to add cycles, just want to add a description of what the cycles are used for.
Cycle 1 - Ball Drill
Cycle 2 - Flat Bottom
Cycle 3 - Gundrill
etc.
Message 6 of 14
Jonathan_Artiss19
@cfastNJWK6
You can save these settings in the toolpath as a strategy, then add an image and name to them? This can be saved as a favorite to appear in the ribbon and your favorites folder.
You could also create a macro to import these strategies, then create a custom tab with images and names and descriptions. The custom ribbon can be exported and delivered to each computer.
These might prove a bit easier than editing and maintaining an installation file which is likely the case with editing within the drilling drop menu.
Jonathan Artiss
Message 7 of 14
cfastNJWK6
@Jonathan_Artiss19
I understand that there are simpler solutions, but I am looking to edit an install file to actually change the drop-down list.  Do you know what file needs to be edited or where it is located?
Message 8 of 14
Jonathan_Artiss19
@cfastNJWK6
I'm not sure which file it would be.
Jonathan Artiss
Message 9 of 14
The safe way: contact your local vendor and ask them for custom localization (~$$).
Or search for the following files:
c:\Program Files\Autodesk\PowerMill XXXX\lib\locale\<Language>\LC_MESSAGES\dcp_messages.mo
c:\Program Files\Autodesk\PowerMill XXXX\lib\locale\<Language>\LC_MESSAGES\form_messages.mo
Back them up.
Open the files in a hex editor and rewrite the text. Attention! The length of the new text must be exactly the same as the original,  and  leave '.' characters alone.
OriginalOriginal
EditEdit
NewNew
Message 10 of 14
cfastNJWK6
Thank you for getting me to the right area.  I actually had to edit files in a slightly different directory:
C:\Program Files\Autodesk\PowerMill 2020\lib\locale\C\LC_MESSAGES\dcp_messages.po
C:\Program Files\Autodesk\PowerMill 2020\lib\locale\C\LC_MESSAGES\form_messages.po
But these files are human read-able so it was actually more simplistic.
Message 11 of 14
Congratulations :). Unfortunately, it's not appropriate for me, because we use the Hungarian language. I think your method works only with English language (I haven't tested it).
Message 12 of 14
Pijetro
Unfortunately, you've voided the warranty....
But will you have to do this everytime a new install or update shows up?
Message 13 of 14
cfastNJWK6
Haha. Yes, it will have to be done for every update.  Luckily, I'm in the position that controls when we roll Powermill updates out to the shop floor so I can stay ahead of the problem.
Message 14 of 14
minh.lenhat
Great help
Le Nhat Minh
