PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Divide program into sub
2 REPLIES 2
j.lacrasse
648 Views, 2 Replies
Hi All,
I'd like to modify my post to divide it per tool and call sub program like this Haas video.
https://www.haascnc.com/video/tipoftheday/nutstjpwjck.html
What would be the step to accomplish it?
J.Lacrasse
2 REPLIES 2
Hey @j.lacrasse
I've done a few of these, they are pretty tricky at first but not impossible.
I can build one for you with your old post, send me a PM for more details.
Jonathan Artiss
Senior Applications Engineer | DSI
Autodesk Expert Elite member
DSI, Design and Software International Autodesk Gold Partner
mark.sully
in reply to: j.lacrasse
You should look in to using Auxiliary Option Files.
This is where you have 2 posts connected together, one that is configured to output the code you want for your main program and the other configured to output the code you want for your sub-program.
In the AMPPU interface, load the post for your main program, go to the "Postprocessor" tab, right-click the post in the tree and select "Load Auxiliary Option File" to load the post for your sub-program.
Then when posting out from PowerMill select the "parent" post for your main program and the linked Auxiliary post will automatically be used as well.
Hope that helps.
