Create Post Processor warning dialog for a particular toolpath
iamcdn79
Mentor Mentor
Message 1 of 43
iamcdn79
There are times when I forget to set cutter comp. to LEFT in the NC Program settings when post processing for Corner Pencil toolpaths. I want to create a warning dialog to say something like cutter comp is not set for this toolpath.
I am wondering if it is possible and how.
I am thinking of creating an if statement like if the toolpath Corner pencil exists and if Cutter Comp is set to None then to pop up a warning when posting.
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Accepted solutions (3)
Replies (42)
Message 41 of 43
Jonathan.Artiss-DSI
This is correct.
If you are using cycles, the expanded cycle would be OFF.
Expanded cycles means cycle output is off, therefore output the cycle in expanded form.
Jonathan Artiss
Senior Applications Engineer | DSI
Autodesk Expert Elite member
DSI, Design and Software International Autodesk Gold Partner
Message 42 of 43
iamcdn79
Ok thanks, I was expecting it to be shown as On in the debugger to match the Nc Program setting form. I tested it and it seems to do what I need.
I didn't think I was using the right one so then I figured to ask you experts but I was just interrupting it backwards in my mind.
Windows 11 Pro
Message 43 of 43
Jonathan.Artiss-DSI
It's looking for the inverse of what you think it should look for.
Cycle on = expanded mode OFF
Cycle off = expanded mode ON
Jonathan Artiss
