Create Post Processor warning dialog for a particular toolpath
iamcdn79
Mentor Mentor
Message 1 of 43
iamcdn79
There are times when I forget to set cutter comp. to LEFT in the NC Program settings when post processing for Corner Pencil toolpaths. I want to create a warning dialog to say something like cutter comp is not set for this toolpath.
I am wondering if it is possible and how.
I am thinking of creating an if statement like if the toolpath Corner pencil exists and if Cutter Comp is set to None then to pop up a warning when posting.
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Accepted solutions (3)
Replies (42)
Message 21 of 43
evo80
Ok, Figured it out.
Message 22 of 43
Jonathan.Artiss-DSI
You call me, and I do it for you 😉
Build a trap to filter the unwanted behavior, create a new user command, and at it to your trap, set the user command to Dissalow, this will cause the post to stop writing and throw a message. You can also set a custom message to the properties of the user command to display in the post information window.
Jonathan Artiss
Senior Applications Engineer | DSI
Autodesk Expert Elite member
DSI, Design and Software International Autodesk Gold Partner
Message 23 of 43
evo80
I'm trying to use the same for thread milling, but this fails every time.
I've tried all manner of different subtype names but nothing seems to fire.
Message 24 of 43
Jonathan.Artiss-DSI
Your subtype is wrong. Use this - %p(Toolpath Strategy Subtype)%=="Thread_Mill"
Jonathan Artiss
Message 25 of 43
iamcdn79
Are you getting all the subtype commands from the Powermill help parameters documentation?
Windows 11 Pro
Message 26 of 43
evo80
Wow, I'm sure I tried that configuration, anyhow I copied and pasted yours and it works, I must've been missing something. So Thanks for that!
Regards
Message 27 of 43
Jonathan.Artiss-DSI
It's case-sensitive, and you had some training words that would also cause it to fail.
Jonathan Artiss
Message 28 of 43
Sean571
I get the sub type from debug view in the post
Sean Wroblewski
Message 29 of 43
evo80
@Sean571
Hi Sean, How is this implemented into the Post Processor?
Message 30 of 43
iamcdn79
I love the "Process as Debug" feature, it helps a lot. I never knew about the Debug View though.
Windows 11 Pro
Message 31 of 43
evo80
I Agree!
That is proper handy.
Message 32 of 43
evo80
Is this the correct syntax to check if an incorrect tool radius has been entered into the Tool Radius Comp Value?
Message 33 of 43
evo80
 I also tried this, but doesn't seem to work either.
The disabled code does work, but i'd really like to check that the correct tool radius has been entered.
Message 34 of 43
evo80
 I couldn't get the Tool Radius check to work so I decided on another route and have the post fill in the tool radius for the helical and threadmilling canned cycles at the tool load stage.
Message 35 of 43
Jonathan.Artiss-DSI
I'm unsure of what you're trying to test for, but if you have it working, then it's correct 😉
Jonathan Artiss
Message 36 of 43
Jonathan.Artiss-DSI
I think I see what you're testing now. This is how I went about doing it.
Do your math inside a user parameter, then test it in your logic.
Jonathan Artiss
Message 37 of 43
evo80
Ah, I see how you've done it. But anyhow by having the post automatically fill in the tool radius I don't need the check.
Still, learned a lot about checking conditions so thanks to all concerned.
Best Regards Jon K
Message 38 of 43
iamcdn79
@Sean571 or @Jonathan.Artiss-DSI do you know what the if statement would be to check if the drilling canned cycle is turned on? I want to add that to my if toolpath strategy subtype = helical statement.
I tried looking in the option settings in the debug view but couldn't find anything drilling cycle or canned cycle
Windows 11 Pro
Message 39 of 43
Jonathan.Artiss-DSI
@iamcdn79
You're looking for "Drilling Expanded Cycle Mode" On and Off are the checks.
Jonathan Artiss
Message 40 of 43
iamcdn79
I tried using that but in the debugger it is showing it as off when clicking on the first cycle def  when it should be on for a toolpath that was posted with drilling cycle output set to on
Windows 11 Pro
