PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Barrel Taper tool
4 REPLIES 4
clifford.gage
1055 Views, 4 Replies
Barrel Taper tool
Hello, is anyone using barrel taper tools.
I'm having some issues where I am getting a different toolpath on different surfaces
The next picture is my first toolpath which is correct
But when I copy this toolpath but select a different surface  I get a different result . the green lines or the cutting path has some vertical movements.
Would this be something to do with the surface?
Would anyone know how to stop this happening?
I am using a surface finishing toolpath
Clifford Gage
4 REPLIES 4
5axes
in reply to: clifford.gage
One solution to create somme toolpath for this type of tool
A) Create a Zconstant toolpath with a ball tool using the same radius as your conical barrel tip radius
B) Create a pattern finishing toolpath using the previous toolpath as pattern
We've tested and never been able to beat a Dijet Mirror Ball finish. Here's our test path, just tipped on the Barrel angle and constant Z
clifford.gage
Morning, I'm not really sure what you mean by a mirrored ball finish. Is that a toolpath?
Or do you just use a constant Z Toolpath using the angle of the tapered tool?
