45 degree reverse chamfer on radial surface
kevin.hammond3WX4X
kevin.hammond3WX4X
Has anyone ever had to machine a reverse chamfer in a hole to a radial surface, looking for suggestions?
I have attempted chamfer milling which produces a flat cycle, i.e. not following pattern ellipse.
I have tried pattern finishing which follows the ellipse but  i cannot seem to offset radially.
Regards Kevin
evo80
Have you tried swarf cutting with reverse axis checked?
evo80
I'm doing a similar job at the moment but rather than a tool as you've describe I'm using a dovetail cutter,
the reverse axis works for this tool but may not for a vee type tool.
evo80
kevin.hammond3WX4X
Hi, thanks for the assist, i managed to create a useable toolpath.
regards Kevin
