2D turning post processor for powermill 2017
Message 1 of 26
Hi is there a 2D turning post processor for powermill 2017? We have a Mazak 3 axis Lathe that uses the C-AXIS. Can you use the new turn feature to generate say a simple Hex on the front of a job using the C, X, Z axis. Thanks
Replies (25)
Message 21 of 26
In Powermill use this macro:
FUNCTION MAIN() {
   DIALOGS MESSAGE OFF
   ENTITY TP=entity('toolpath','')
   IF error($TP) {
      DIALOGS MESSAGE ON
      RETURN
   IF $TP.Strategy != 'turn_roughing' {
      DIALOGS MESSAGE ON
      RETURN
   IF NOT member($TP.UserParameters._keys,"RoughXThickness" ) {
      EDIT USERPAR toolpath  $TP.Name NAME 'RoughXThickness'
      EDIT USERPAR toolpath  $TP.Name TYPE 'Real'
      CREATE USERPAR toolpath $TP.Name
   $TP.Userparameters.RoughXThickness=$TP.Turning.RoughXThickness
   IF NOT member($TP.UserParameters._keys,"RoughZThickness" ) {
      EDIT USERPAR toolpath  $TP.Name NAME 'RoughZThickness'
   $TP.Userparameters.RoughZThickness=$TP.Turning.RoughZThickness
   DIALOGS MESSAGE ON
In Postprocessor create two userdefined parameter: udp_RoughZThickness and udp_RoughZThickness.
User parameters with udp_ prefixUser parameters with udp_ prefix
Message 22 of 26
I need post processor for 2 axis (x,z) for siemens controller. Please help me for this
Message 23 of 26
sarat.cnc
Observer
Observer
need post-processor for lathe fanuc control.
Message 24 of 26
bonk_za
Disturb those who know.
How should I fix this?
Message 25 of 26
Meysam_Ghorbani
Message 26 of 26
kainar115
HELLO FRIEND, IT WOULD BE GREAT IF YOU SEND THE POST PROCESSOR.😊
