Point Layout Forum
Welcome to Autodesk’s Point Layout Forums. Share your knowledge, ask questions, and explore popular Point Layout topics.
Point Layout and Core Locations
9 REPLIES 9
Message 1 of 10
1662 Views, 9 Replies
Greetings!  I've just started looking at Point Layout and I was wondering if it's possible to add points only where, say, pipes intersect a wall or floor.  Maybe there's a workaround for this?  Or maybe I need to brush up on my Dynamo skills?  Thanks in advance!
9 REPLIES 9
Message 2 of 10
s.hamel
I believe that functionality went out in the 2017 R1 release. Try doing a Pipe or Conduit routine (Under the MEP panel on the Point Layout Ribbon in Revit), a few questions in it should offer you " Clash/Intersections with Slabs/Floors/Walls" as one of the options. Let me know how that goes.
Shayne Hamel
Shayne Hamel
Manager, Principal Software Engineering
Message 3 of 10
in reply to: s.hamel
Great, thanks Shayne!
Message 4 of 10
Hi Shayne,
I'm not able to get this to work. I'm just not seeing that option. I'm using 2017 R1.
Also, I've tried selecting pipe from a linked file and couldn't get that to work either. I've gone into "Settings==>Revit" and selected "Search Linked Revit Models for Points", but it still won't let me select any pipe from the linked file. If I bind the linked file I can then select the pipe from that file.
Any ideas? I'm I just not using it correctly?
Terry Jordan | Virtual Construction Coordinator
Ryan Companies US, Inc. | 625 1st Street SE, Suite 175, Cedar Rapids, IA 52401
319-731-2839 tel | 319-440-0665 cell | 319-731-2939 fax
terry.jordan@ryancompanies.com
[Description: RY]
Find us on: The Web| Twitter | Facebook
Message 5 of 10
s.hamel
Terry, check this picture, it shows where the Clash option is offered.  If you are not seeing that, I think you are actually on the initial 2017 release, in which case just grab the update from here.
Here is the result of running this on a pipe going through a wall.
In regards to the Search Linked models option, this only makes points that were created in those linked models available for export/Comparison/Manage Pts.  To create points on those models you would still need to bind them or open them directly.
Shayne
Shayne Hamel
Message 6 of 10
Yep, that was it! I was just missing the "Clashes" button. Thanks so much, Shayne!
Message 7 of 10
ben
@s.hamel I've tried this using Revit 2022 and don't seem to have any luck. The points don't seem to generate
Revit lives in the land of perfect and doesn't understand what construction is.
Message 8 of 10
s.hamel
in reply to: ben
You mean with a pipe going through a slab or something similar?
Shayne Hamel
Message 9 of 10
ben
correct
Message 10 of 10
s.hamel
in reply to: ben
Just did a quick test in Revit 2022 and appears to still work fine:
Will need further information or a test file from you to look any further.
Shayne Hamel
