Here is what you will find new in the 2015 release of Autodesk Point Layout:
General:
- Support for AutoCAD/Revit/Navisworks 2015 releases.
- New Preview guide with separate sections for AutoCAD, Revit, and Navisworks.
- Code mapping functionality added: Codemapping allows the user to map descriptions to a Code, and include these mapped codes when creating their export files. Various field Layout software's will use this code to control the visual display of points.
- Return Network License: Users on network licenses can now return their licenses without closing out of Revit or AutoCAD. Navisworks will automatically return it's license when the button pallet is closed.
- Network Licensing: Will now automatically check for and use environment variable if it exists.
- Better support for Metric value entry added anywhere the need was found.
AutoCAD:
- Support for Advanced Concrete custom grids added to Control Points Mark grid intersections function.
- Increased compatibility with Autodesk Fabrication items.
- Electrical tab now uses Electrical point type when adding Conduit hangers/points.
Revit:
- Dynamic point descriptions: Points can now contain triggers that allow the description to contain values pulled from parameters of the point, or the family the point is nested in.
- Point Cloud Analysis fine level control: Users can now specify the maximum number of points to be analyzed per face, and the average distance between points to be analyzed, allowing for a high level of control over the analysis and processing time.
- Slab Analysis/Point Cloud Analysis now allow negation of values. This allows, for one example, analysis done from a reflected ceiling view of a slab to report positive values when the deviation is below the slab.
- When exporting points, user can now append to an existing points file.
- All ribbon items now have their own icons.
- Option to export to DWG format alongside current DXF export option.
Navisworks:
- Automapping and Codemapping now available within Navisworks
- Navisworks points orgin now set to be within the bounding area of existing models to avoid expanding the federated models bounding area when large coordinate systems are used.
- Automated point creation on selected objects.
- Increased compatibility with Non-English versions
If you have questions in regards to specific new features please feel free to post here or send me a PM. While the documentation has been greatly expanded, the best place to seek advice on advanced workflows or specific features will be this board.
Shayne
Shayne Hamel
Manager, Principal Software Engineering
