Point Layout Forum
Welcome to Autodesk’s Point Layout Forums. Share your knowledge, ask questions, and explore popular Point Layout topics.
Attempt to modify the module outside of transaction
4 REPLIES 4
561 Views, 4 Replies
Received this error message today when trying to use APL to select all points in a view.
"Attempt to modify the module outside of transaction"
Please advise.
4 REPLIES 4
Tried restarting revit. Still get error.
Ok, So if I click Modify in APL and then Cancel, Then Click select all. It works.
Believe I solved this one... Turns out I was forgetting to check for duplicates after making changes.
s.hamel
This was a bug in 2021, and will go away in 2022 release. It will only happen if you have unnumbered nested points, which isn't very common since most functions will cause them to be assigned a number.
Shayne Hamel
Manager, Principal Software Engineering
