Received this error message today when trying to use APL to select all points in a view.
"Attempt to modify the module outside of transaction"
Please advise.
This was a bug in 2021, and will go away in 2022 release. It will only happen if you have unnumbered nested points, which isn't very common since most functions will cause them to be assigned a number.
