ObjectARX
Jig Dimension Scale disappeared when zoom in
13 REPLIES 13
Message 1 of 14
KIMHENGHOR98
829 Views, 13 Replies
When I zoomed in the Jig Dimension had been disappeared using below code :1.PNG2.PNGscaleDim.PNG
13 REPLIES 13
Message 2 of 14
@KIMHENGHOR98 wrote:
When I zoomed in the Jig Dimension had been disappeared using below code :2.PNG
It is look like value of dimension is very small. So dimension can not be drawn as you expected.
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 14
But by using Line command it is still appearing . What difference between my method ??
Message 4 of 14
tbrammer
in reply to: KIMHENGHOR98
In your code both the values of s and the length of mMajorAxis depend on VIEWSIZE. So the length of the vector s*mMajorAxis.perpVector() is roughly (VIEWSIZE*VIEWSIZE) which becomes small very fast if you zoom in.  Try s*(mMajorAxis.perpVector().normalize()) instead.
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
Message 5 of 14
Message 6 of 14
KIMHENGHOR98
in reply to: tbrammer
I got another error here when wrapper is created :
Message 7 of 14
tbrammer
What kind of error? Compiler error? Does it complain about the red underlined symbols? Looks like you need to include some more headers.
For a COM wrapper sample have a look at <ARX>\samples\com\AsdkSquareWrapper_dg.
Message 8 of 14
KIMHENGHOR98
I found that some files was not created 😫
Message 9 of 14
KIMHENGHOR98
One more problem is that : I wanted my Entity to be always red ,So that I need to remove Common Color Property. Is it possible ??
Message 10 of 14
KIMHENGHOR98
The first problem is solved but the second is not ::
Message 11 of 14
KIMHENGHOR98
**ObjectARX**
How to Print ObjectID into Command Line?
Can I access Microsoft Excell by using Command in AutoCad??
Message 12 of 14
tbrammer
I would recomment to print the AutoCAD handle instead of the ObjectID. This is the easiest way:
acutPrintf(L"Handle=%s", AcString(objectId.handle()).constPtr());
The AutoCAD LIST command also shows the handle of entities, so it is easy for you to identify objects.
Bear in mind that the handle is
  • persistent: If you save and reload the DWG, the handlestring remains unchanged.
  • only unique within one AcDbDatabase.
Regarding Excel: This should be possible with class AcDbDataLink / class AcDbDataLinkManager / class AcDbLinkedTableData  or through COM. Have a look at this older .NET sample.
Message 13 of 14
KIMHENGHOR98
**I might as well need more an example for accessing Excel with ObjectARX**
**One more problem is that : I wanted my Entity to be always red ,So that I need to remove Common Color Property. Is it possible ??**
Message 14 of 14
@KIMHENGHOR98
Please create new topics for every questions which not correspondent to topic title.
Expert Elite Member
Forma Design Contest
AutoCAD Beta
