ObjectARX
Create Custom Entity
3 REPLIES 3
nathan307
1028 Views, 3 Replies
Dear Friends,
      I am beginer to ObjectArx in C++,I want to create a Custom Entity in ObjectArx with C++.I alredy read All previous Discustion About CustomEntity Creation,But I don't Understood How to Create Custom Entity,I need Your Help With Some Samplecode to create CustomEntity And Display the Name in Property Window,able to set Properties to the Custom Entities.
thanks.....
3 REPLIES 3
Alfred.NESWADBA
in reply to: nathan307
Please look to your previous post (about ArcAlignedText), there I have shown the link to the correct forum for >>>AutoCAD ObjectARX<<<.
There is the place for development based on ObjectARX, this forum here is not for development, it's for "how to use (existing) AutoCAD's functionality".
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
owenwengerd
The ObjectARX SDK contains numerous samples. If you tell us which version you're using, someone may be able to point you to a specific example.
Owen Wengerd
ManuSoft
nathan307
in reply to: Alfred.NESWADBA
Dear friend,
  Thanks For ur Suggestion...
   I am New to this Forum.  So I don't Know the Correct Place to post MyPost,That is the reson I post Again in Same Place...
Forma Design Contest
AutoCAD Beta
