ObjectARX
AcEdInputPointMonitor::monitorInputPoint final
6 REPLIES 6
1175 Views, 6 Replies
I draw additional info on my custom object when the user selects the object, such as the object's local user axis system as well as its origin point. Previously I did this by over-riding AcEdInputPointMonitor::monitorInputPoint in a special class in the "UI" part of my code (arx part) where I could get a grip on the AcGiViewportDraw* drawContext and so add geometry, such as lines and a circle, to the viewport.
In "acedinpt.h" comments in the new SDK, it notes that this function now is final and states that it will be removed in a future releases.
Can you please let me know what the new/alternative method would be to accomplish this functionality.
JP
6 REPLIES 6
Alexander.Rivilis
You have to use other overloaded method:
virtual Acad::ErrorStatus monitorInputPoint(const AcEdInputPoint& /*input*/,
AcEdInputPointMonitorResult& /*output*/);
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
in reply to: Alexander.Rivilis
Hi Alexander,
Thanks for the reply. I saw this function and tried to implement it. However, I cannot seem to access AcGiViewportDraw* drawContext (which i need to draw in the model space around my custom object). I have seen in the header file that *AcEdInputPointMonitorResult do implement a friend class "friend class AcEdImpInputPointManager" and this pointer do contain "ACAD_PORT AcGiViewportDraw* drawContext() const;".
Can you please assist in how to return "AcEdInputPointMonitorResult& /*output*/" whilst utilising the drawContext in AcEdImpInputPointManager;
JP
Alexander.Rivilis
Simple sample drawing circle around current point:
Acad::ErrorStatus PointMonitor::monitorInputPoint(const AcEdInputPoint& inpt /*input*/,
  AcEdInputPointMonitorResult& outpt /*output*/)
  if (inpt.pointComputed()) {
     AcGePoint3d pCenter = inpt.computedPoint();
     inpt.drawContext()->geometry().circle(pCenter, 10.0, inpt.drawContext()->viewport().viewDir());
  return Acad::eOk;
Expert Elite Member
In the old monitorinputpoint function(before AC2021) the apertureEntities argument exists. But the new function it does not exists in AcEdInputPoint. How to get apertureEntities in monitorinputpoint function.
Alexander.Rivilis
Try to check pickedEntities() method of AcEdInputPoint class.
Expert Elite Member
Thanks a lot for the information. I will try.
Forma Design Contest
AutoCAD Beta
