Unexpected results! worldDraw() question!
I have created a test entity, mjbSmiley. It simply a happy face with a
center an a diameter member variable. Now I was able to save this but when I
opened it, the mouth and eyes were missing. I created the features in
worldDraw(). Now, I thought worldDraw was responsible for drawing the
object. Here is my code:
Adesk::Boolean mjbSmiley::worldDraw(AcGiWorldDraw* mode)
assertReadEnabled();
double dOffset = (m_dia / 1) / 5;
AcGeVector3d vecVert(0.0, dOffset, 0.0);
AcGeVector3d vecHorz(dOffset, 0.0, 0.0);
AcGePoint3d leftEye, rightEye, leftCorner, bottom, rightCorner;
leftEye = (m_center - vecHorz) + vecVert;
rightEye = (m_center + vecHorz) + vecVert;
leftCorner = m_center - vecHorz;
bottom = m_center - vecVert;
rightCorner = m_center + vecHorz;
mode->subEntityTraits().setColor(4);
mode->geometry().circle(m_center, m_dia / 2, AcGeVector3d(0.0, 0.0, 1.0));
mode->subEntityTraits().setColor(3);
mode->geometry().circle(leftEye, m_dia / 10, AcGeVector3d(0.0, 0.0, 1.0));
mode->geometry().circle(rightEye, m_dia / 10, AcGeVector3d(0.0, 0.0, 1.0));
mode->subEntityTraits().setColor(1);
if(!Adesk::kFalse == mode->geometry().circularArc(leftCorner, bottom,
rightCorner, kAcGiArcSimple))
printf("Mouth unsuccessful!");
return AcDbEntity::worldDraw(mode);
Acad::ErrorStatus mjbSmiley::dwgInFields(AcDbDwgFiler* pFiler)
assertWriteEnabled();
Acad::ErrorStatus es;
// Call dwgInFields from AcDbEntity
if ((es = AcDbEntity::dwgInFields(pFiler)) != Acad::eOk) {
return es;
// Read version number.
Adesk::UInt16 version;
pFiler->readItem(&version);
if (version > VERSION_MJBSMILEY)
return Acad::eMakeMeProxy;
// Read the data members.
switch (version)
case (1):
pFiler->readPoint3d(&m_center);
pFiler->readDouble(&m_dia);
break;
return pFiler->filerStatus();
Acad::ErrorStatus mjbSmiley::dwgOutFields(AcDbDwgFiler* pFiler) const
// Call dwgOutFields from AcDbEntity
if ((es = AcDbEntity::dwgOutFields(pFiler)) != Acad::eOk) {
return es;
// Write version number.
pFiler->writeItem((Adesk::UInt16) VERSION_MJBSMILEY);
pFiler->writePoint3d(m_center);
pFiler->writeDouble(m_dia);
Now, why did worldDraw not draw the eyes and mouth of my mjbSmiley entity?
Mike B
Hi Mike,
I tested your code for fun and didn't have any problems... I changed the
class name and added the code to the AcGi traits sample... The complete
entity code is pasted below. I suspect that the problem has to do with the
initialization of the m_center and m_dia variables. You might try steping
through the code to make sure these values are always populated with correct
numbers.
Here's the code I tested. You can build it just by replacing the
.\docsamps\acgismps\traits\traits.cpp with the code below.
#include
#include
#include
#include
#include "aced.h"
#include "dbsymtb.h"
#include "dbapserv.h"
#include "acgi.h"
// function prototypes
// THE FOLLOWING CODE APPEARS IN THE SDK DOCUMENT.
static Acad::ErrorStatus
getLinetypeIdFromString(const char* str, AcDbObjectId& id); static
Acad::ErrorStatus getLayerIdFromString(const char* str, AcDbObjectId& id);
// END CODE APPEARING IN SDK DOCUMENT.
class AsdkTraitsSamp: public AcDbEntity
public:
ACRX_DECLARE_MEMBERS(AsdkTraitsSamp);
virtual Adesk::Boolean worldDraw(AcGiWorldDraw *);
Acad::ErrorStatus transformBy(const AcGeMatrix3d &);
Acad::ErrorStatus dwgOutFields(AcDbDwgFiler* pFiler) const;
Acad::ErrorStatus dwgInFields(AcDbDwgFiler* pFiler);
double m_dia;
AcGePoint3d m_center;
ACRX_DXF_DEFINE_MEMBERS(AsdkTraitsSamp,AcDbEntity,
AcDb::kDHL_CURRENT, AcDb::kMReleaseCurrent, 0,\
ASDKTRAITSSAMP,AsdkTraits Sample);
Acad::ErrorStatus AsdkTraitsSamp::transformBy(
const AcGeMatrix3d &xfm)
return Acad::eOk;
Adesk::Boolean AsdkTraitsSamp::worldDraw(AcGiWorldDraw* mode)
AcGePoint3d leftEye, rightEye, leftCorner, bottom, rightCorner; leftEye =
(m_center - vecHorz) + vecVert; rightEye = (m_center + vecHorz) + vecVert;
leftCorner = m_center - vecHorz; bottom = m_center - vecVert; rightCorner
Acad::ErrorStatus AsdkTraitsSamp::dwgInFields(AcDbDwgFiler* pFiler) {
assertWriteEnabled(); Acad::ErrorStatus es;
return es;
if (version > 1.0)
switch (version)
case (1):
break;
Acad::ErrorStatus AsdkTraitsSamp::dwgOutFields(AcDbDwgFiler* pFiler) const {
assertReadEnabled(); Acad::ErrorStatus es;
return es;
pFiler->writeItem((Adesk::UInt16) 1.0); pFiler->writePoint3d(m_center);
void
addAsdkTraitsSampObject()
AsdkTraitsSamp *pNewObj = new AsdkTraitsSamp;
pNewObj->m_center = AcGePoint3d(0.0,0.0,0.0);
pNewObj->m_dia = 10.0;
AcDbBlockTable *pBlockTable;
acdbHostApplicationServices()->workingDatabase()
->getSymbolTable(pBlockTable, AcDb::kForRead);
AcDbBlockTableRecord *pBlock;
pBlockTable->getAt(ACDB_MODEL_SPACE, pBlock,
AcDb::kForWrite);
AcDbObjectId objId;
pBlock->appendAcDbEntity(objId, pNewObj);
pBlockTable->close();
pBlock->close();
pNewObj->close();
static void initAsdkTraitsSamp()
AsdkTraitsSamp::rxInit();
acrxBuildClassHierarchy();
acedRegCmds->addCommand("ASDK_TRAITS_SAMP",
"ASDKTRAITSSAMP",
"TRAITSSAMP",
ACRX_CMD_TRANSPARENT,
addAsdkTraitsSampObject);
extern "C" AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg, void* appId)
switch(msg) {
case AcRx::kInitAppMsg:
acrxDynamicLinker->unlockApplication(appId);
acrxDynamicLinker->registerAppMDIAware(appId);
initAsdkTraitsSamp();
break;
case AcRx::kUnloadAppMsg:
acedRegCmds->removeGroup("ASDK_TRAITS_SAMP");
deleteAcRxClass(AsdkTraitsSamp::desc());
return AcRx::kRetOK;
"Mike B" wrote in message
news:7B0C737280ED923191B164F25D12A3B1@in.WebX.maYIadrTaRb...
I
1.0));
1.0));
1.0));
> return es;
> switch (version)
> case (1):
> break;
> return es;
> Mike B
