I can save my custom entity but I cannot open
I cannot open my entity in autocad. I am getting an exception error (Null
Pointer ?) 0xC0000005 right after the open command. If someone can help me
with this, it would be greatly appreciated!
** Retrieve entity data into drawing when opening. **
Acad::ErrorStatus PSIHollowcore::dwgInFields(AcDbDwgFiler* pFiler)
assertWriteEnabled();
Acad::ErrorStatus es;
// Call dwgInFields from AcDbEntity
if ((es = AcDbEntity::dwgInFields(pFiler)) != Acad::eOk) {
return es;
// Read version number.
Adesk::UInt16 version;
pFiler->readItem(&version);
if (version > VERSION_PSIHOLLOWCORE)
return Acad::eMakeMeProxy;
// Read the data members.
switch (version)
case (1):
int nShape, nBoundary;
pFiler->readItem(&nShape);
pFiler->readItem(&nBoundary);
pFiler->readItem(&m_dLength);
pFiler->readItem(&m_dWidth);
pFiler->readItem(&m_dThickness);
AcGePoint3d temp;
for(int i = 0; i < nShape; i++)
pFiler->readItem(&temp);
m_ptsShape.append(temp);
for(i = 0; i < nBoundary; i++)
m_ptsBoundary.append(temp);
break;
return pFiler->filerStatus();
** Save entity object to dwg when saving. **
Acad::ErrorStatus PSIHollowcore::dwgOutFields(AcDbDwgFiler* pFiler) const
assertReadEnabled();
// Call dwgOutFields from AcDbEntity
if ((es = AcDbEntity::dwgOutFields(pFiler)) != Acad::eOk) {
return es;
// Write version number.
pFiler->writeItem((Adesk::UInt16) VERSION_PSIHOLLOWCORE);
pFiler->writeItem(m_dLength);
pFiler->writeItem(m_dWidth);
pFiler->writeItem(m_dThickness);
int nShape = m_ptsShape.length();
int nBoundary = m_ptsBoundary.length();
pFiler->writeItem((Adesk::UInt16) nShape);
pFiler->writeItem((Adesk::UInt16) nBoundary);
pFiler->writeItem(m_ptsShape);
pFiler->writeItem(m_ptsBoundary);
m_ptsShape, and m_ptsBoundary are both AcGePoint3dArray objects. Any ideas?
Mike B
I changed the order of some events in the dwgOutFields
This still does not work.
Any ideas?
hi, Guy!no one will bother to told you any word that really
values, unless you pay to AutoDesk!
you are lucky enough that I 've got lots and lots of experience of
customize entity, so if you do trust me, send your
code and I'll examine it. Think about it, I am the one
who really wanna help you.
to kittywwxx@sina.com
