Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Support directory
Support directory
Support directory
Hello
It is possible to set a new Autocad support directory (like
_options ->fichier->Support Folder -> addnew) directly from the code with a
Object ARX method ?
Thx
modify system registry!!!
"Pelloq1" wrote in message
news:[email protected]...
> Hello
a
> Object ARX method ?
> Thx
Thank you !
I test now that to change the ACAD reg key ....
Do you use this ? that work properly ?
"Lcm" wrote in message
> > Hello
with
> a
> > Object ARX method ?
> > Thx
It realy work!,the key and the value are some string like below:
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R??.?\ACAD-?:???\Profiles\YourP
rofileName\General]
"ACAD"="C:\\MyPath1;C:\\MyPath2;D:\\ProgramFiles\\AutoCAD
2002\\support;D:\\ProgramFiles\\AutoCAD
2002\\fonts;D:\\ProgramFiles\\AutoCAD
2002\\help;D:\\ProgramFiles\\YourPath3;"
> Thank you !
> > > Hello
> with
> > a
> > > Object ARX method ?
> > > Thx
