Support directory
Support directory
Support directory
Hello
It is possible to set a new Autocad support directory (like
_options ->fichier->Support Folder -> addnew) directly from the code with a
Object ARX method ?
Thx
modify system registry!!!
"Pelloq1" wrote in message
news:790C503615B1F63585D18FF3DF24DB90@in.WebX.maYIadrTaRb...
> Hello
a
> Object ARX method ?
> Thx
Thank you !
I test now that to change the ACAD reg key ....
Do you use this ? that work properly ?
"Lcm" wrote in message
news:78D37F802F365088650B95F1FF02387C@in.WebX.maYIadrTaRb...
> > Hello
with
> a
> > Object ARX method ?
> > Thx
It realy work!,the key and the value are some string like below:
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R??.?\ACAD-?:???\Profiles\YourP
rofileName\General]
"ACAD"="C:\\MyPath1;C:\\MyPath2;D:\\ProgramFiles\\AutoCAD
2002\\support;D:\\ProgramFiles\\AutoCAD
2002\\fonts;D:\\ProgramFiles\\AutoCAD
2002\\help;D:\\ProgramFiles\\YourPath3;"
news:4ABD733EB0AF2F9BF7F449808A862F10@in.WebX.maYIadrTaRb...
> Thank you !
> > > Hello
> with
> > a
> > > Object ARX method ?
> > > Thx
