polyline with arc
polyline with arc
polyline with arc
Here is one question troubled me for a while.When I use AcGe, I found polyline can only express LineSegs, If I want convert Curves(linesegs and arcs) into polyline, Is there any class can use?
Thank you!
Alexander.Rivilis
Functions acdbConvertAcDbCurveToGelibCurve() and acdbConvertGelibCurveToAcDbCurve() (begining only with ObjectARX SDK 2012) can help you convert DB-curve to GE-curve and vice versa
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Thanks a lot.
I mean that AcGePolyline3d can only Express Linear Entities, If I want describe both LineSeg and Arc use AcGePolyline3d, how can I do?
Alexander.Rivilis
From ObjectARX SDK Docs: AcGePolyline3d Represents a piecewise linear spline entity in 3D space.
That is why you have to using AcGeCompositeCurve3d class in order to represent connected end to end linear and arc segments, but can not using AcGePolyline3d
Expert Elite Member
I used AcGeAugPoyline3d instead, it looks fit my target.
