Custom Entity 3DORBIT
When 3DORBIT used, the deleted Custom Entity always shown on the screen, and it will disappeared when quit the command.
Why?
StephenPreston
That is not expected behavior. However, its impossible to say what you may have done wrong in your custom entity implementation to cause it without seeing any code. If you're an ADN member, then you're welcome to submit your question via DevHelp Online on the ADN website. If not, then someone may be willing to take a look at your code if you post it here. (
In either case, please don't submit any code you consider to be confidential).
Cheers,
Stephen Preston
Autodesk Developer Network
Thank you.Smiley Happy
