Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
ObjectARX 2022: acHeapAlloc/acHeapFree LNK2001
dario_bellinazzi
dario_bellinazzi
on our HLR api implementation I get LNK2001 error on acHeapAlloc and acHeapFree definitions:
LNK2001 external symbol unresolved "void __cdecl acHeapFree(void *,void *)"
(?acHeapFree@@YAXPEAX0@Z)
LNK2001 external symbol unresolved "void * __cdecl acHeapAlloc(void *,unsigned __int64)"
(?acHeapAlloc@@YAPEAXPEAX_K@Z)
I get this only on when compiling with ObjectARX 2022, previous versions works fine. I've double checked inclusion/libs directories and additional dependencies, all seems equivalent to our ObjectARX 2021 configuration.
Thank you for your support.
  • 2022
moogalm
Autodesk Support
Autodesk Support
Can you please try linking with ~\ObjectARX2022\lib-x64\AcPal.lib
dario_bellinazzi
Thank you Madhukar,
I confirm that linking AcPal.Lib fixes our linking problem.
phenriet
worked well for me too, thanks !
john4TMYX
Thank you. It works for me as well.
