Multiple entity jig
Multiple entity jig
karl.sch1983
Multiple entity jig
karl.sch1983
Hello everyone. I have used the logic at https://adndevblog.typepad.com/autocad/2013/01/jig-more-than-one-entity-with-acedjig-class-in-object... to jig a circle and line. My screencast is attached. The circle jig completes and then the line jig continues. Is there a way to have them update together.
I tried using AcEdInputPointFilter but still no luck. In this case the entities do not update at all until the command returns.
Any thoughts/suggestions on how to approach this. Maybe there is a better way other than jig and point monitor to update multiple entities? Thanks in advance.
tbrammer
Here is a modifikation of the sample project from https://adndevblog.typepad.com/autocad/Downloads/JigEntities.zip
It was ported to Acad 2020. I think it does what you want. The relevant changes are in JigEntitiesCommands.cpp. Compare it to the original version to see what I changed.
Thomas Brammer ● Software Developer ● imos AG ● LinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
karl.sch1983
Thanks a ton. I really appreciate it. Since my original post https://forums.autodesk.com/t5/objectarx/jig-multiple-entity/m-p/10131544 , I have spent a good 3 weeks trying to solve this issue. Can't believe it was so simple. Thanks again.
