Smartpointer question?
D_D_K
D_D_K
can I combine AcDbObjectPointer and AcDbVoidPtrArray ?
The problem I'm having is the pointer doesn't seem to be valid after the end of the function.
How do I use smartpointer in this case? because I want to avoid delete pointer.
bool Dosomething(AcDbCircle* c,...); //
void myfunc(AcDbVoidPtrArray &vrr){
AcDbObjectPointer<CIR> cptr; cptr.create();
CIR* cir = cptr.object();
if (Dosomething(cir,...))
   vrr.append(cir);
 Thanks for the explanation.
Alexander.Rivilis
   vrr.append(cir);
if (Dosomething(cir,...)) {
   CIR *cir1 = NULL;
   cir.release(cir1); // <- prevent from destructor
   vrr.append(cir1);
Other way is not using smart pointer in this case.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
D_D_K
Thank sir!
I got it. maybe I'll save it for other cases. 🗯
trithuongle
Good morning , I have a question .
With the above sample , when AcDbObjectPtrArray vrr go out of its scope in main function , do we need to delete or close its member 's pointers ?
I also have the similar code in which i'm using AcDbObjectPtrArray.
Thanks in advance !
AcDbVoidPtrArray lineObjs;
    AcDbObjectPointer<AcDbLine> tempLine;
    AcDbObjectId oId;
    ads_point startPnt, nextPnt;
    acedGetPoint(NULL, _T("\nStart point : "), startPnt);
    for (int i = 0; i < 10; i++)
        acedGetPoint(startPnt, _T("\nNext point : "), nextPnt);
        tempLine.create();
        tempLine->setStartPoint(asPnt3d(startPnt));
        tempLine->setEndPoint(asPnt3d(nextPnt));
        tempLine->setLayer(_T("1"));
        addToCurSpace(oId, tempLine);
        AcDbLine* pTemp = nullptr;
        tempLine.release(pTemp);
        lineObjs.append(pTemp);
        acdbPointSet(nextPnt, startPnt);
    acutPrintf(_T("\nNumber of lines : %d"), lineObjs.length());
    //<- do we need to delete or close AcDbVoidPtrArray 's member pointer here ?
    //If not does it cause memory leak ?
