Importing Page setup from another file
Dear colleagues,
Is there an easy way to import Page setup from another file? Practically what you get when you click on "import" in "Page setup manager" dialogue? Are these objects AcDbPlotSettings?
I wouldn't like to use acedCommandS, of course, but on the other hand I don't want to open whole new database, search just for that one object in Plot settings dictionary, and close it. Is there any shortcut?
tbrammer
Try this:
Acad::ErrorStatus ImportPlotSettings(AcDbDatabase *pDbTarget, LPCWSTR pcImportFile, LPCWSTR pcPlotSettingsName)
	Acad::ErrorStatus es;
	AcDbDatabase *pDbSource = new AcDbDatabase(false, true); // no defaults, no Document
	es = pDbSource->readDwgFile(pcImportFile);     // DWG that holds your page setup
	AcDbDictionary *pDict = 0;
	es = pDbSource->getPlotSettingsDictionary(pDict, AcDb::kForRead);
	if (es == Acad::eOk)
		AcDbObjectId myPlotsettingId;
		es = pDict->getAt(pcPlotSettingsName, myPlotsettingId); // get your page setup
		pDict->close();
		AcDbPlotSettings *pPS = NULL, *pPsCopy = NULL;
		if ( (es=acdbOpenObject(pPS, myPlotsettingId, AcDb::kForRead)) == Acad::eOk )
			pPsCopy = new AcDbPlotSettings(false);
			es = pPsCopy->copyFrom(pPS);
			pPS->close();
		if (pPsCopy)
			es = pPsCopy->addToPlotSettingsDict(pDbTarget);
				pPsCopy->close();
			else
				delete pPsCopy;
				pPsCopy = NULL;
	delete pDbSource;
	return es;
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
Thanks, this idea is clear and straight forward.
I would just like to ask you about LPCWSTR type, I haven't seen it before and cant find much in documentation, that's some sort of light weight string type or something?
Alexander.Rivilis
LPCWSTR is the same as const ACHAR *
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
