How To Rotate a AcDbviewport
How To Rotate a AcDbviewport Use ObjectArx
As Use "Rotate" Command In CAD2010 or later
tbrammer
Do you want to rotate the AcDbViewport entity within the paperspace layout?
You can do this the same way as you would rotate any other entity using AcDbEntity::transformBy(const AcGeMatrix3d &mat) with an appropriate matrix.
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
