Copying custom object to new drawing - problem with save
Hi, I have encountered a strange behaviour.
I draw my custom entity on DRAWING1.
Then I copy it, using CTRL+C.
Next, I create a new drawing and paste this object using CTRL+V.
Everything seems to work fine, but neither subDeepClone, nor subWblockClone gets called. Then, when I try to save the new drawing, the files is saved, but I get a message: "Warning: There was an error while saving the file. You should call REPAIR command for this drawing."
After I call REPAIR or audit it finds no errors.
What could be the reason?
owenwengerd
The problem is in your dwgOutFields() and dwgInFields() functions, likely not filing out a needed hard reference or a reference to an object in a different database.
Owen Wengerd
ManuSoft
It's not that. I don't have any such references. I call AcDbEntity::dwgOut and then write some ints to the filer. That'a all.
This problem is connected with: http://forums.autodesk.com/t5/objectarx/custom-copy-mechanism/td-p/5917404
