Custom copy mechanism
Hi, I need something like custom copy mechanism. It should work like that:
1. When a _COPYCLIP command is invoked I need to stop it.
2. Then my mechanism should be invoked
3. When a _PASTECLIP is invoked I need to stop it.
4. And call my mechanism to paste entity.
What's more, this should be only for my custom entities. For AutoCAD entities, Autocad copy & paste mechanism should be invoked.
The problem is that part of my entities are not copyable. And I don't want Autocad to copy them. I tried to return eInapplicable in subDeepClone and subwBlockClone, but it ended up in an error message. Any ideas?
owenwengerd
You can create your own COPYCLIP and PASTECLIP commands to replace the built-in commands. If you really must prevent the built-in commands from executing you'll need to veto() them during AcApDocManagerReactor::documentLockModeChanged().
Owen Wengerd
ManuSoft
So there is another question.
I don't have any selection set. Then start COPYCLIP. This command then let me chose entities to copy - so it creates a new selection set. Is there any way to get to this selection set and check what's in it? PickfirstModified doesn't get called in such case.
nick83
so, if you need to prevent coping try this:
http://adndevblog.typepad.com/autocad/2012/05/disabling-copy-command-for-certain-entities.html
or this:
http://adndevblog.typepad.com/autocad/2013/01/prevent-coping-of-the-entity.html
Well veto command this way works. I wish it could work in commandWillStart - it would be more predictable. I accepted this as solution, because it really stopped these commands. But it occured that this is not all what makes my problems.
It's something with my application, and unfortunately I will have to solve it by myself.
