Extremely slow debuging load
Hi all
Is anyone else having the problem with VS .net that the process of loading
modules and checking for debug symbols takes forever - it takes me about 3
minutes to strike up a debugging session.
Andy
"Andrew le Bihan" schrieb:
> Hi all
> loading modules and checking for debug symbols takes forever - it
> takes me about 3 minutes to strike up a debugging session.
> Andy
first of all, it takes long ...:-(. However, take a look at your
debugger settings, an make sure that only "native code" is selected
(unless you are also debugging .NET). This speeded up things on my
machine a lot, but it still takes more than a minute.
HTH,
Andy
To mail me directly, remove the NO*SPAM parts in
NO*SPAMxmen40@gmx.netNO*SPAM
I have the same problems, I think its only with the "locked" version of
AutoCAD, perhaps some of our American friends can comment of the speed of
debugging with the unlocked version, then we can get together and maybe get
something done via the ADN network.
"Andreas Müller" wrote in message
news:63C7E344A5E665ED4F447E3A3FCC9A9B@in.WebX.maYIadrTaRb...
> > Hi all
> > Andy
> Hi,
> HTH,
> Andy
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.512 / Virus Database: 309 - Release Date: 19/08/2003
I have the same problem, and it has only been since AutoCAD moved to VS 7.
In AutoCAD 2002, it was not this painfully slow. Sometimes it takes up to 5
minutes to catch a breakpoint. Sometimes I think that AutoCAD is about to
crash, but really it's just VC++ running like a dog.
Jon
"Andy R" wrote in message
news:82EE2293A4E00416A46E3B17E11A6B74@in.WebX.maYIadrTaRb...
get
> > > Hi all
> > > Andy
> > Hi,
> > HTH,
> > Andy
Andrew le Bihan wrote:
> Hi all
> Andy
Check to see if you have the _NT_SYMBOL_PATH environment variable set to
download from the Microsoft symbol server.
| Byron Blattel
| CADwerx---Applications for AutoCAD
| Autodesk Registered Developer
| email: byron@cadwerx.net
| web site: http://www.cadwerx.net
| Custom Programming Services
> debugging with the unlocked version...
I am using the unlocked 2004 version with VC++ 7.0 Standard and have not
seen delays like you are talking about. The only modifications I have made
to the debug settings were to disable Just-in-time debuging (but I did not
notice any difference in debuging speed after making this change). Debuging
is a little slower than it was with VC++ 6, but it is only a minor
inconviniance.
Justus
get
> > > Hi all
> > > Andy
> > Hi,
> > HTH,
> > Andy
> Hi all
> Andy
I just found out, that when I start AutoCAD myself and attach the
debugger manually, everything works pretty fast, breakpoints are catched
right away,..... I guess I'll stick with that.
HTH,
Andy
