Double click action causes the can not save problem
I have two dwg-files, in dwgA, the double click action on any element (like text, dimension) will causes the problem of can not save the current file. But in dwgB, it will not.
So, what's the problem for the dwgA? And how to solve this problem?
Thank you!
And here are the two files.
Alfred.NESWADBA
there are a lot of SHX missing, so I guess we can't test anything in the same environment (or you look to missing SHX's too).
DWG B needs recovery (1226 errors, 6 objects erased) when I open your drawing with AutoCAD 2017.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Thank you for your reply.
And I have solved the problems you prompted, and used common SHXs.
But the double click problem is still there (for A.dwg).
Alexander.Rivilis
Is this your custom double click reaction or AutoCAD standard reaction? If your custom reaction - I do not see code. If standard reaction - you selected wrong forum. Also you did not specify AutoCAD version and updates.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Sorry.
It's AutoCAD standard reaction.
I'll change the forum now.
