converting Arc to Polyline
Message 1 of 10
Is there any way to convert Arc to Polyline in Object Arx, I need to convert two arcs into a single polyline. PEDIT, dosesn't seem work as it calls PEDIT command instead of joining to arcs and creating one polyline out of those. Any help is appreciated.
Harshad
Replies (9)
Message 2 of 10
Alexander.Rivilis
Hope this code help you start with joining lines/arcs in polyline:
//----- acrxEntryPoint.cpp
#include "StdAfx.h"
#include "resource.h"
#define szRDS _RXST("")
//----- ObjectARX EntryPoint
class CJoinToPlineApp : public AcRxArxApp {
public:
  CJoinToPlineApp () : AcRxArxApp () {}
  virtual AcRx::AppRetCode On_kInitAppMsg (void *pkt) {
    AcRx::AppRetCode retCode = AcRxArxApp::On_kInitAppMsg (pkt) ;
    return (retCode) ;
  virtual AcRx::AppRetCode On_kUnloadAppMsg (void *pkt) {
    AcRx::AppRetCode retCode = AcRxArxApp::On_kUnloadAppMsg (pkt) ;
    return (retCode) ;
  virtual void RegisterServerComponents () {
  static void JoinToPlineJoinToPline () {
    // Фильтр для выбора отрезков (LINE) и дуг (ARC)
    ACHAR* promptPtrs[] = {
      _T("\nSelect lines and arcs for join in poyline (ENTER - exit): "),
      _T("\nRemove lines and arcs from selection set: ")
    ads_name ss;
    resbuf *rbFilter = acutBuildList(RTDXF0,_T("LINE,ARC"),RTNONE);
    int rc = acedSSGet(_T(":$"),promptPtrs,NULL,rbFilter,ss);
    acutRelRb(rbFilter);
    if (rc != RTNORM) return;
    AcDbObjectIdArray ids;
    if (ObjectIdArrayFromSelSet(ss, ids) != Acad::eOk) return;
    while (ids.length() > 0)
      AcDbEntity *p = MakeJonedPoly(ids);
      if (p) {
        AcDbBlockTableRecordPointer pSpace(acdbCurDwg()->currentSpaceId(), AcDb::kForWrite);
        if (pSpace.openStatus() != Acad::eOk) return;
        pSpace->appendAcDbEntity(p);
        p->close();
      } else {
        acutPrintf(_T("\nError in data!"));
        return;
  /// <summary>
  /// AcDbObjectIdArray from SelectionSet
  /// </summary>
  /// <param name="sset">SelectionSet</param>
  /// <param name="ids">AcDbObjectIdArray</param>
  /// <returns></returns>
  static Acad::ErrorStatus ObjectIdArrayFromSelSet(ads_name sset, AcDbObjectIdArray &ids)
    Acad::ErrorStatus es = Acad::eOk;
    long nset = -1;
    if (acedSSLength(sset,&nset) != RTNORM) return Acad::eAmbiguousInput;
    ids.setLogicalLength(nset);
    ads_name en;
    AcDbObjectId id;
    for (long i=0; i < nset; i++) {
      if (acedSSName(sset,i,en) == RTNORM) {
        if ((es = acdbGetObjectId(id,en)) != Acad::eOk) return es;
        ids[i] = id;
    return Acad::eOk;
  /// <summary>
  /// Create polyline from lines and arcs.
  /// Those ids will remove from input array
  /// </summary>
  /// <param name="ids">Array of id's</param>
  /// <param name="FUZZ">The accuracy of determining the distance between points</param>
  static AcDbPolyline* MakeJonedPoly(
    AcDbObjectIdArray &ids,
    double FUZZ = AcGeContext::gTol.equalPoint())
    AcDbPolyline *p = new AcDbPolyline();
    p->setDatabaseDefaults();
    AcDbObjectId idFirst = ids[0];
    AcGePoint3d nextPt = AcGePoint3d::kOrigin;
    AcGePoint3d prevPt = AcGePoint3d::kOrigin;
    AcDbObjectPointer<AcDbCurve> c(idFirst,AcDb::kForRead);
    if (c.openStatus() == Acad::eOk) {
      AcGePoint3d ptStart, ptEnd;
      c->getStartPoint(ptStart); c->getEndPoint(ptEnd);
      p->addVertexAt(0, asPnt2d(asDblArray(ptStart)), BulgeFromArc(c, false), 0, 0);
      p->addVertexAt(1, asPnt2d(asDblArray(ptEnd)), 0, 0, 0);
      nextPt = ptEnd;
      prevPt = ptStart;
    ids.remove(idFirst);
    int prevCnt = ids.length() + 1;
    while (ids.length() > 0 && ids.length() < prevCnt)
      prevCnt = ids.length();
      for (int i = 0; i < ids.length(); i++) {
        AcDbObjectId id = ids[i];
        AcDbObjectPointer<AcDbCurve> cv(id,AcDb::kForRead);
        if (cv.openStatus() == Acad::eOk) {
          cv->getStartPoint(ptStart); cv->getEndPoint(ptEnd);
          if (ptStart.distanceTo(nextPt) < FUZZ || ptEnd.distanceTo(nextPt) < FUZZ) {
            double bulge = BulgeFromArc(cv, ptEnd.distanceTo(nextPt) < FUZZ);
            p->setBulgeAt(p->numVerts() - 1, bulge);
            if (ptStart.distanceTo(nextPt) < FUZZ)
              nextPt = ptEnd;
            else
              nextPt = ptStart;
            p->addVertexAt(p->numVerts(), asPnt2d(asDblArray(nextPt)), 0, 0, 0);
            ids.remove(id);
            break;
          } else if (ptStart.distanceTo(prevPt) < FUZZ || ptEnd.distanceTo(prevPt) < FUZZ) {
            double bulge = BulgeFromArc(cv, ptStart.distanceTo(prevPt) < FUZZ);
            if (ptStart.distanceTo(prevPt) < FUZZ)
              prevPt = ptEnd;
            else
              prevPt = ptStart;
            p->addVertexAt(0, asPnt2d(asDblArray(prevPt)), bulge, 0, 0);
            ids.remove(id);
            break;
    if (p->numVerts() == 0) {
      delete p;  return NULL;
    }  else  {
      return p;
  /// <summary>
  /// Getting bulge of curve
  /// </summary>
  /// <param name="c">AcDbCurve pointer</param>
  /// <param name="clockwise">direction.</param>
  static double BulgeFromArc(AcDbCurve *c, bool clockwise)
    double bulge = 0.0;
    AcDbArc *a = AcDbArc::cast(c);
    if (a == NULL) return bulge;
    double newStart =
      (a->startAngle() > a->endAngle()) ?
      (a->startAngle() - 8 * atan(1.0)) :
      (a->startAngle());
    bulge = tan((a->endAngle() - newStart) / 4.0);
    if (clockwise) bulge = -bulge;
    return bulge;
IMPLEMENT_ARX_ENTRYPOINT(CJoinToPlineApp)
ACED_ARXCOMMAND_ENTRY_AUTO(CJoinToPlineApp, JoinToPline, JoinToPline, JoinToPline, ACRX_CMD_MODAL, NULL)
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 10
Thanks for the help, Earlier calling _.PEDIT like below, it now calls PEDIT command instead of joining two entities. Is this option or any such option no longer exists in new ARX framework?
(acedCommandS(RTSTR, _T("_.PEDIT"), RTENAME, ent1, RTSTR, _T("YES"), RTSTR, AO_join, RTENAME, ent2, RTSTR, Null_str, 0);
Harshad
Message 4 of 10
Alexander.Rivilis
@Anonymous
Do you want to merge segments only using the _PEDIT command and do not like my code for joining? OK.
#include "StdAfx.h"
#include "acedCmdNF.h"
class CMyJoinApp : public AcRxArxApp {
public:
  CMyJoinApp() : AcRxArxApp() {}
  virtual AcRx::AppRetCode On_kInitAppMsg(void *pkt) {
    AcRx::AppRetCode retCode = AcRxArxApp::On_kInitAppMsg(pkt);
    return (retCode);
  virtual AcRx::AppRetCode On_kUnloadAppMsg(void *pkt) {
    AcRx::AppRetCode retCode = AcRxArxApp::On_kUnloadAppMsg(pkt);
    return (retCode);
  virtual void RegisterServerComponents() {}
  static void RivilisMyJoin() {
    ads_name en1;  ads_point p;
    while (acedEntSel(_T("\nSelect first segment: "), en1, p) == RTNORM)
      bool bConvertToPoly = false;
      AcDbObjectId id1; acdbGetObjectId(id1, en1);
      if (id1.objectClass() == AcDbLine::desc() ||
          id1.objectClass() == AcDbArc::desc())
        bConvertToPoly = true;
      ads_name en2;
      if (acedEntSel(_T("\nSelect next segment: "), en2, p) == RTNORM)
        if (bConvertToPoly)
          acedCommandS(RTSTR, _T("_PEDIT"), RTENAME, en1, RTSTR, _T("_YES"), RTSTR, _T("_Join"),
            RTENAME, en2, RTSTR, _T(""), RTSTR, _T(""), RTNONE);
        else
          acedCommandS(RTSTR, _T("_PEDIT"), RTENAME, en1, RTSTR, _T("_Join"),
IMPLEMENT_ARX_ENTRYPOINT(CMyJoinApp)
ACED_ARXCOMMAND_ENTRY_AUTO(CMyJoinApp, Rivilis, MyJoin, MyJoin, ACRX_CMD_MODAL, NULL)
Video of MyJoin command:
Expert Elite Member
Message 5 of 10
Hello Alex,
Thanks for your help you ever do, I am converting the old code to new ARX version, so thought of doing minumum changes, I ever appreciate your help and use it in my work, thanks a ton for the same. My purpose was to check if by some means, with minimal changes what was doable, I am going to use the code you gave me, thanks a ton for the same.
Harshad
Message 6 of 10
Alexander.Rivilis
I've just remembered that the command _PEDIT is affected by the system variable PEDITACCEPT. So more accurate code is:
#include "StdAfx.h"
public:
    return (retCode);
    return (retCode);
    // Check PEDITACCEPT sysvar
    resbuf rb = { 0, RTSHORT, 0 };
    acedGetVar(_T("PEDITACCEPT"), &rb);
    bool bPeditAccept = (rb.resval.rint == 1) ? true : false;
      // if PEDITACCEPT == 1 then PEDIT no ask about converting
      if (!bPeditAccept)
      ads_name en2;
        if (bConvertToPoly)
        else
Expert Elite Member
Message 7 of 10
Thanks a lot Alex! That worked!!
Message 8 of 10
jayhar
I draw two Arch & use comment Joint. Then i check properties its being Polyline
Thank you
Jayhar.M.J
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Message 9 of 10
Automohan
I need to know how to run the code in Autocad with a screencast ?
thanks
Automohan
"Save Energy"
Did you find this reply helpful? If so please use the Accept as Solution
Message 10 of 10
jayhar
Please try it
