Custom commands and shortcuts
damir_vidakovic
damir_vidakovic
I am trying to implement a way for the user so he can define a shortcut for some different custom commands.
I can implement it in a several ways, and it is not a problem in general. What I'm trying to find is a list of current shortcuts in AutoCAD, because I would like when user tries to set new shortcut for a custom command (e.g. CTRl+ something), that I tell him if this shortcut was used already, and for what. Is it possible to get current shortcuts from code?
Damir Vidakovic
www.studioars.com
moogalm
Autodesk Support
Autodesk Support
Hi
Command Key bindings are stored Shortcut Key node of CUIX
You can retrieve
 public static void GetShortCutKeys()
            string mainCuiFile = (string)Application.GetSystemVariable("MENUNAME");
            mainCuiFile += ".cuix";
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            CustomizationSection cs = new CustomizationSection(mainCuiFile);
            AcceleratorCollection acCollection = cs.MenuGroup.Accelerators;
            Dictionary<string, string> keyValuePairs = new Dictionary<string, string>();
            foreach (MenuAccelerator menuAcltr in acCollection)
                ed.WriteMessage(String.Format("{0}\t:\t{1}",menuAcltr.ShortcutName(),menuAcltr.ShortcutKey()) + "\n");
                keyValuePairs.Add(menuAcltr.ShortcutName(), menuAcltr.ShortcutKey());
