Convert entity Arc Revit into entity Arc Autocad
sizy458
sizy458
How convert information extracted from "Autodesk.Revit.DB.Arc" Revit Application  for reproduce Arc on entity Arc Autocad  ?
I will passe data converted into constructor entity Arc Autocad .
The arc is wrong and different from arc revit
How do i do ?
Autocad.Net
Arc a = new Arc(pacadcen, vctcirc, cgh.Radius, cgh.AngleFrom, cgh.AngleTo);
var doc = AcAp.DocumentManager.MdiActiveDocument;
var db = doc.Database;
Autodesk.AutoCAD.DatabaseServices.TransactionManager tm = db.TransactionManager;
BlockTable bt = (BlockTable)tm.GetObject(db.BlockTableId, OpenMode.ForRead, false);
BlockTableRecord btr = (BlockTableRecord)tm.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite, false);
btr.AppendEntity(a);
tm.AddNewlyCreatedDBObject(a, true);
I'am since 1 day.
Thank.
Virupaksha_aithal
Autodesk Support
Autodesk Support
what is going wrong? Can you please provide deatils about what you are expecting and the ARC created by AutoCAD API.
also, You need to use .NET forum to log AutoCAD.net API related issues https://forums.autodesk.com/t5/net/bd-p/152
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
