COmpile ArxDbg
COmpile ArxDbg
COmpile ArxDbg
I am using Visual Studio 2017 and ObjectARX_2019. When trying to compile ArxDbg project, I get no errors but the solution does not compile. Is there any step by step guide explaining how to compile. I am grateful for any help. I tried searching through the forums and found a few links where compiled ArxDbg.arx files are available for download, but as I am learning I wanted to compile the file from the sln file in SDK.
tbrammer
What do you mean by "does not compile"? What happens if you compile the project?
I have attached a short screen cast recording from my build procedure (german version of Visual Studio).
What is different at your side?
I noticed that the Win32 project configuration still exist though it doesn't make sense anymore.
Make sure that you build the x64 configuration!
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
