Can not connvert int to AcDbObjectIdArray error when NULL is assign to AcDbObjectIdArray variable in ObjectARX 2023.
nkokate052
Message 1 of 9
nkokate052
Please resolve this issue.
If I assign NULL to AcDbObjectIdArray variable in ObjectARX 2023 in visual studio 2019 it is giving error can not convert from int to AcDbObjectIdArray. Screen shot is attached with this.
Example :
AcDbObjectIdArray arrObj = NULL;
this giving error can not convert from int to AcDbObjectIdArray.
Accepted solutions (3)
Replies (8)
Message 2 of 9
tbrammer
Just write  AcDbObjectIdArray arrObj;   to get an empty array.
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
Message 3 of 9
nkokate052
but i have to set default value to AcDbObjectIdArray variable in function declaration.
What can I do to set default value?
Message 4 of 9
tbrammer
AcDbObjectIdArray has a very nice default constructor that creates an empty array of AcDbObjectIds. You just don't need a default value. If you insist in assigning a default value (i.e. for syntactical reasons) you can do something like this:
AcDbObjectIdArray emptyIdArray; // global variable
void fkt() {
    AcDbObjectIdArray ids1 = emptyIdArray;
    AcDbObjectIdArray ids2 = AcDbObjectIdArray();
AcDbObjectIdArray is a typedef:
    typedef AcArray<AcDbObjectId> AcDbObjectIdArray;
The assignment operator of AcArray<T,R> only accepts another AcArray:
    AcArray<T,R>&         operator =  (const AcArray<T,R>&);
    AcArray<T,R>&         operator =  (AcArray<T,R>&&);
Message 5 of 9
autodaug
It sounds like you might be passing the array by value, as in:  myfunc(AcDbObjectIdArray idArr)
That's not usually the best practice, because it can cause unnecessary copying of the array during func calls.
If the array is not being modified, you can pass a const ref, as in:  myfunc(const AcDbObjectIdArray & idArr)
And if it *is* being modified, then pass it as a non-const ref: myfunc(AcDbObjectIdArray & idArr)
Or, if the array arg is optional, you can make it a ptr :  myfunc(const AcDbObjectIdArray *pArr = nullptr);
Message 6 of 9
daniel_cadext
looks like you're trying to do an optional argument, you can pass by pointer.
    static void Foo()
        AcDbObjectIdArray ids;
        func(10, &ids);
        acutPrintf(_T("\nfoo %ld"), ids.length());
    static void Far()
        func(10);
        acutPrintf(_T("\nfar = %ld"), ids.length());
    static void foobar()
        std::unique_ptr<AcDbObjectIdArray> pids; //is null
        func(10, pids.get());
        if (pids)
            acutPrintf(_T("\nfoobar = %ld"), pids->length());
        else
            acutPrintf(_T("\nfoobar = %ld"), 0);
    static void furbar()
        std::unique_ptr<AcDbObjectIdArray> pids(new AcDbObjectIdArray());
        if (pids)
            acutPrintf(_T("\nfurbar = %ld"), pids->length());
        else
            acutPrintf(_T("\nfurbar = %ld"), 0);
    static void func(size_t cnt, AcDbObjectIdArray* ids = nullptr)
        if (ids != nullptr)
            for (size_t idx = 0; idx < cnt; idx++)
                ids->append(AcDbObjectId::kNull);
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
Message 7 of 9
tbrammer
As I suggested before you can pass a default value to a function like this:
int defArr(AcDbObjectIdArray arr = AcDbObjectIdArray());
 or like this:
//Header file:
extern AcDbObjectIdArray defaultIdArray; // global variable
int defArr2(AcDbObjectIdArray arr=defaultIdArray);
//CPP file:
int defArr2(AcDbObjectIdArray arr) {
    return arr.length(); //i.e.
@autodaug's approach is a little more efficient.
But if you don't want to change function signatures you can do it like this.
Message 8 of 9
autodaug
I agree, if you want to pass the array by value, and have a default parameter, then it should be = AcDbObjectIdArray()
The second approach with the global defaultIdArray object is more complicated and less flexible, imo.
Message 9 of 9
daniel_cadext
I assumed it was an [in][out] parameter, with a global or a new there's no way to know since there's no null.
