Create and Insert Blocks? Create and Insert AnonBlock?
1127204185
1127204185
static void MyGroupMyCommand () {
	ads_name ss = { 0 };
	int ret = acedSSGet(NULL, NULL, NULL, NULL, ss);
	AcDbObjectIdArray ids;
	if (RTNORM == ret)
		long len = 0;
		acedSSLength(ss, &len);
		for (long i = 0L; i < len; ++i)
			ads_name ename = { 0 };
			acedSSName(ss, i, ename);
			AcDbObjectId id = AcDbObjectId::kNull;
			acdbGetObjectId(id, ename);
			ids.append(id);
		acedSSFree(ss);
	CreateBlock1(_T("TTT"),ids,AcGeScale3d(1,1,1),0);  // Create and Insert Blocks
AcDbObjectId AnonblockId ;
CreateAnonBlock(ids,AnonblockId);
static AcDbObjectId CreateBlock1(const CString &blkName, const AcDbObjectIdArray &idObjectArray,const AcGeScale3d &m_aScale,const double &m_angle)
	 AcDbBlockTable *pBlkTbl = NULL;
	 acdbHostApplicationServices()->workingDatabase()->getBlockTable(pBlkTbl, AcDb::kForWrite);
	 AcDbBlockTableRecord *pBlkRcd = new AcDbBlockTableRecord();
	 pBlkRcd->setName(blkName);
	 AcDbObjectId blkDefId;
	 pBlkTbl->add(blkDefId, pBlkRcd);
	 pBlkTbl->close();
	 AcDbObjectId entId;
	 for (INT32 i = 0; i < idObjectArray.length(); i++)
	 AcDbEntity *pEntity = NULL;
	 acdbOpenAcDbEntity(pEntity, idObjectArray.at(i), AcDb::kForRead);
	 pBlkRcd->appendAcDbEntity(entId, pEntity);
	 pBlkRcd->close();
	 AcDbBlockReference *pBlkRef = new AcDbBlockReference(AcGePoint3d::kOrigin, entId);
	 pBlkRef->setScaleFactors(m_aScale);
	 PostToModelSpace(pBlkRef);
	 pBlkRef->setRotation (m_angle) ;
	 return entId;
static Acad::ErrorStatus CreateAnonBlock(AcArray<AcDbObjectId> &selectedIds, AcDbObjectId &idAnonBlock)
                Acad::ErrorStatus es;
                AcDbBlockTable *pBlockTable = NULL;
                AcDbDatabase *pDb = acdbHostApplicationServices()->workingDatabase();
                AcDbBlockTableRecord *pAnonBlock = NULL;
                if( idAnonBlock == AcDbObjectId::kNull )
                        if ((es = pDb->getBlockTable(pBlockTable, AcDb::kForWrite))
                                != Acad::eOk)
                                acutPrintf(L"Could not open block table 无法打开块表.\n");
                                return es;
                        AcDbBlockTableRecord* pAnonBlock = new AcDbBlockTableRecord;
                        if(!pAnonBlock)
                                acutPrintf(L"Could not create new block table record.无法创建新的块表记录\n");
                                return Acad::eNullObjectPointer;
                        if((es = pAnonBlock->setName(_T("*U"))) != Acad::eOk)
                                acutPrintf(L"Could not name anonymous block.无法命名匿名块\n");
                                return es;
                        if((es = pBlockTable->add(idAnonBlock, pAnonBlock)) != Acad::eOk)
                                acutPrintf(L"Could not add anonymous block to block table.无法将匿名块添加到块表\n");
                                return es;
                        if((es = pBlockTable->close()) != Acad::eOk)
                                acutPrintf(L"Could not close block table.\n");
                                return es;
                        if((es = pAnonBlock->close()) != Acad::eOk)
                                acutPrintf(L"Could not close block table record.\n");
                                return es;
                AcDbObjectPointer<AcDbBlockTableRecord> pAnonBlockObjectPtr(idAnonBlock, AcDb::kForWrite);
                if((es = pAnonBlockObjectPtr.openStatus()) != Acad::eOk)
                        acutPrintf(L"Could not open anonymous block.\n");
                        return es;
                for(int cnt = 0; cnt < selectedIds.length(); cnt++)
                        AcDbObjectId entId = selectedIds.at(cnt);
                        AcDbObjectPointer<AcDbEntity> pEntity(entId, AcDb::kForRead);
                        if(Acad::eOk == pEntity.openStatus())
                                AcDbEntity *pCloneEnt = (AcDbEntity *) pEntity->clone();
                                if((es = pAnonBlockObjectPtr->appendAcDbEntity(pCloneEnt)) != Acad::eOk)
                                        acutPrintf(L"Could not append entity to anonymous block.\n");
                                        return es;
                                if((es = pCloneEnt->close()) != Acad::eOk)
                                        acutPrintf(L"Could not close entity.\n");
                                        return es;
                return Acad::eOk;
tbrammer
There are three bugs in CreateBlock1(..):
1.) You are trying to append entities that are already in modelspace to the new block. You can't do that! Instead clone() the entities and insert their clones - just like you do it in CreateAnonBlock().
2.) You are passing the wrong ObjectId to  new AcDbBlockReference(.., entId).
It must be new AcDbBlockReference(.., blkDefId).
3.) I assume that PostToModelSpace(entity) closes entity. So you must call
pBlkRef->setRotation(m_angle) before PostToModelSpace(pBlkRef).
f your PostToModelSpace(entity) doesn't close the entity you have to close it yourself!
The function CreateAnonBlock() is OK as far as I can see. It creates the unnamed block - but it doesn't append a BREF to it in the modelspace.
Below is working code. Note that the BREFs overlap the original entities:
Acad::ErrorStatus PostToModelSpace(AcDbEntity* pEntity)
	AcDbObjectId objId;
    AcDbBlockTable *pBlockTable;
    AcDbBlockTableRecord *pSpaceRecord;
        ->getSymbolTable(pBlockTable, AcDb::kForRead);
    pBlockTable->getAt(ACDB_MODEL_SPACE, pSpaceRecord,
        AcDb::kForWrite);
    pBlockTable->close();
    pSpaceRecord->appendAcDbEntity(objId, pEntity);
    pEntity->close();
    pSpaceRecord->close();
    return Acad::eOk;
static AcDbObjectId CreateBlock1(const CString &blkName, const AcDbObjectIdArray &idObjectArray, const AcGeScale3d &m_aScale, const double &m_angle)
	es = pBlkRcd->setName(blkName);
	pBlkTbl->close();
	AcDbObjectId entId;
		//TB: You can't append an entity to another block that is already in the modelspace.
		//Instead clone it and append the clone:
		AcDbEntity *pNewEntity = AcDbEntity::cast(pEntity->clone());
		pEntity->close();
		es = pBlkRcd->appendAcDbEntity(entId, pNewEntity);
		if (es)
			delete pNewEntity;
		else
			pNewEntity->close();
	pBlkRcd->close();
	AcDbBlockReference *pBlkRef = new AcDbBlockReference(AcGePoint3d::kOrigin, blkDefId); //TB was entId
	//TB: I assume that PostToModelSpace(ent) closes the entity. So you must...
	pBlkRef->setRotation(m_angle); // ...do this _before_ PostToModelSpace().
	return entId;
	if (idAnonBlock == AcDbObjectId::kNull)
			!= Acad::eOk)
			return es;
		AcDbBlockTableRecord *pAnonBlock = new AcDbBlockTableRecord;
		if (!pAnonBlock)
		if ((es = pAnonBlock->setName(_T("*U"))) != Acad::eOk)
			return es;
		if ((es = pBlockTable->add(idAnonBlock, pAnonBlock)) != Acad::eOk)
			return es;
		if ((es = pBlockTable->close()) != Acad::eOk)
			return es;
		if ((es = pAnonBlock->close()) != Acad::eOk)
			return es;
	if ((es = pAnonBlockObjectPtr.openStatus()) != Acad::eOk)
		return es;
	for (int cnt = 0; cnt < selectedIds.length(); cnt++)
		if (Acad::eOk == pEntity.openStatus())
			AcDbEntity *pCloneEnt = (AcDbEntity *)pEntity->clone();
			if ((es = pAnonBlockObjectPtr->appendAcDbEntity(pCloneEnt)) != Acad::eOk)
				return es;
			if ((es = pCloneEnt->close()) != Acad::eOk)
				return es;
	return Acad::eOk;
// MyCommand / MC
static void MyGroupMyCommand() {
	if (RTNORM == ret)
		Adesk::Int32 len = 0;
			ids.append(id);
		acedSSFree(ss);
	CreateBlock1(_T("TTT"), ids, AcGeScale3d(1, 1, 1), 0);  // Create and Insert Blocks
	AcDbObjectId AnonblockId;
	CreateAnonBlock(ids, AnonblockId); // You don't insert a BREF to AnonblockId
	AcDbBlockReference *pBlkRef = new AcDbBlockReference(AcGePoint3d::kOrigin, AnonblockId); //TB was entId
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
thank you!
Not reserved  ids。Only blocks!
I don't know if this is right!
Why must pEntity->clone()
			 != Acad::eOk)
			 return es;
		 if (!pAnonBlock)
			 return es;
			 return es;
			 return es;
			 return es;
		 return es;
		 AcDbObjectPointer<AcDbEntity> pEntity(entId, AcDb::kForWrite);
				 return es;
				 return es;
          pEntity->erase();
		  pEntity->close();
	 return Acad::eOk;
	 pBlkTbl->close();
	 AcDbObjectId entId;
		 acdbOpenAcDbEntity(pEntity, idObjectArray.at(i), AcDb::kForWrite);
		 if (es)
			 delete pNewEntity;
		 else
		 pEntity->erase();
		 pEntity->close();
	 pBlkRcd->close();
	 return entId;
tbrammer
See my comment
You tried to append the entities that you selected to another block.  But these entities are alredy in the modelspace block. So you must either append clones from these entities or use
AcDbBlockTableRecord::assumeOwnershipOf(const AcDbObjectIdArray &entitiesToMove);
To move them from the modelspace to another block.
