Boolean Operation
Boolean Operation
Boolean Operation
HI COM,
In this code i want to subtract to solid a solid clone.
//open main entity
if(acdbOpenObject(entMain,idMainAcDb::kForWrite)==Acad::eOk)
AcDb3dSolid *myMainSolid=AcDb3dSolid::cast(entMain);
//open tool entity
       if(acdbOpenObject(entTool,idTool,AcDb::kForWrite)==Acad::eOk)
             //clone tool entity
             AcDb3dSolid *myCloneSolid=AcDb3dSolid::cast(entTool->clone());
entTool ->close(); //close tool entity
es= myMainSolid->booleanOper(AcDb::kBoolSubtract, myCloneSolid);
myCloneSolid->close();
             delete myCloneSolid;
             myCloneSolid=NULL;
entMain->close();
I have two objectS in the model space and i open each in the write mode.
The first object is the main solid, the second is the "tool" solid.
I clone the tool solid and in this way the boolean operation doesn’t work.
The error code is ‘eWasOpendedForWrite’ but the tool entity is been closed before the operation.
If I add the solid clone to model space  and re-open the Id, the operation works. is it right? why?
Bruno
owenwengerd
Maybe you have solid history enabled, and the shallow clone still references the solid history sub-object of the source solid?
Owen Wengerd
ManuSoft
tbrammer
Owen is right. Your code works well for solids without history - but not for those with history.
I tried to disable history using myCloneSolid->setRecordHistory(false)/setShowHistory(false) but that didn't help. It seems there is no other way to subtract solids with history than to append them to the DB. I found no other API to handle the history.
I still wonder why this happens. The AcDb3dSolid is a "hard owner" of its AcDbShHistory. In fact the original solid and its shallow clone both point to the same history object during the boolean operation. But why is this a problem?
But the more important question is: How can we handle this problem other than appending the clone to the DB and erase() it afterwards?
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
we found the solution disabling hystory on both solids:
//open tool entity
             //clone tool entity
myMainSolid->setRecordHistory(false);
             myCloneSolid->setRecordHistory(false);
             myCloneSolid=NULL;
entMain->close();
In this way it works.
Bruno
Alexander.Rivilis
This line of code:
is superfluous as myCloneSolid is not database resident object.
Facebook | Twitter | LinkedIn
Expert Elite Member
Alexander.Rivilis
@Anonymous
It is look like enough to clear history of main 3DSOLID:
static void RivilisBoolSub () {
  ads_name en1, en2;  ads_point p;
  Acad::ErrorStatus es;
  if (acedEntSel(L"\nSelect main 3DSOLID: ", en1, p) == RTNORM &&
      acedEntSel(L"\nSelect tool 3DSOLID: ", en2, p) == RTNORM) {
    AcDbObjectId id1, id2;
    acdbGetObjectId(id1, en1); acdbGetObjectId(id2, en2);
    AcDbObjectPointer<AcDb3dSolid> pMainSol(id1, AcDb::kForWrite);
    AcDbObjectPointer<AcDb3dSolid> pToolSol(id2, AcDb::kForWrite);
    if (pMainSol.openStatus() == Acad::eOk && pToolSol.openStatus() == Acad::eOk) {
      AcDb3dSolid *pCloneTool = new AcDb3dSolid();
      // Creating clone of pToolSolid:
      pCloneTool->setASMBody(pToolSol->ASMBodyCopy(false));
      pToolSol->close();
      // Clear history of main Solid
      if (pMainSol->recordHistory())
        pMainSol->setRecordHistory(false);
      es = pMainSol->booleanOper(AcDb::kBoolSubtract, pCloneTool);
      delete pCloneTool;
AutoCAD 2017 video:
Expert Elite Member
Hi Alexander,
thank you so much. Great work.
Bruno
