How to use AcDbIndexFilterManager::getFilter Function
I wanna change the clip box of a block-ref, so I tried to get the AcDbSpatialFilter *pFilter of the block, like this
	AcDbBlockReference *pBlkRef = NULL;
	if (Acad::eOk != acdbOpenObject(pBlkRef, idBlk, AcDb::kForWrite))
		return false;
	AcDbSpatialFilter *pFilter = NULL;
	Acad::ErrorStatus es = AcDbIndexFilterManager::getFilter(pBlkRef, AcDbSpatialFilter::desc(), AcDb::kForRead, pFilter);
	pBlkRef->close();
but comes the err
1>..\Common\Entity\BlockUtil.cpp(546) : error C2665: “AcDbIndexFilterManager::getFilter”: 2 个重载中没有一个可以转换所有参数类型
1>        d:\objectarx\objectarx2010\inc\dbindex.h(179): 可能是“Acad::ErrorStatus AcDbIndexFilterManager::getFilter(const AcDbBlockReference *,const AcRxClass *,AcDb::OpenMode,AcDbFilter *&)”
1>        d:\objectarx\objectarx2010\inc\dbindex.h(184): 或       “Acad::ErrorStatus AcDbIndexFilterManager::getFilter(const AcDbBlockReference *,int,AcDb::OpenMode,AcDbFilter *&)”
1>        试图匹配参数列表“(AcDbBlockReference *, AcRxClass *, AcDb::OpenMode, AcDbSpatialFilter *)”时
it must be the err of the value put in for the const AcRxClass* key
Acad::ErrorStatus
getFilter(
const AcDbBlockTableRecord* pBlkRef,
const AcRxClass* key,
AcDb::OpenMode readOrWrite,
AcDbFilter*& pFilter);
pBlkRef Input block reference from which to get the filter
key Input class descriptor that is used as a key, to get to the filter
readOrWrite Input mode in which to open the object
pFilter Returns the filter
  So how to use the AcDbIndexFilterManager::getFilter Function to get the pFilter of the block-ref?
Alexander.Rivilis
Instead of
try to use:
Acad::ErrorStatus es = AcDbIndexFilterManager::getFilter(pBlkRef, AcDbSpatialFilter::desc(), AcDb::kForRead, (AcDbFilter*&)pFilter);
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
OH.. Thank you !
Sorry for my careless...
I should be more careful..
