@Anonymous wrote:
Thanks Alexander for quick reply.
Below blog says that no C++ SDK and only .Net Arx supported?
http://adndevblog.typepad.com/aec/2014/03/is-there-a-cobjectarx-sdk-for-autocad-mep.html
Sorry, but you misunderstood this blog. Main idea is:
The ARX SDK will work with Vanilla AutoCAD and AutoCAD verticals based on it.
AutoCAD MEP is a one of AutoCAD verticals, so you can use ObjectARX (C++) to work with AutoCAD MEP. But there is no unmanaged API (such as ObjectARX) which can use work with specific MEP functionality.
Facebook | Twitter | LinkedIn
