Arx compiled for ACAD 2017 using C++ ObjectArx 2017, can be used in MEP & Elect
Arx compiled for AutoCAD 2017 using C++ ObjectArx 2017, is it possible to use same Arx in AutoCAD MEP 2017 and AutoCAD Electrical 2017 without recompiling?
Sudeep
Alexander.Rivilis
Yes. These arx-files can be used in all AutoCAD 2017 verticals.
Facebook | Twitter | LinkedIn
Expert Elite Member
Thanks Alexander for quick reply.
Below blog says that no C++ SDK and only .Net Arx supported?
http://adndevblog.typepad.com/aec/2014/03/is-there-a-cobjectarx-sdk-for-autocad-mep.html
Alexander.Rivilis
Sorry, but you misunderstood this blog. Main idea is:
The ARX SDK will work with Vanilla AutoCAD and AutoCAD verticals based on it.
AutoCAD MEP is a one of AutoCAD verticals, so you can use ObjectARX (C++) to work with AutoCAD MEP. But there is no unmanaged API (such as ObjectARX) which can use work with specific MEP functionality.
Expert Elite Member
