ALLOW_RTCc_IN_STL preprocessor usage
ranga.narasimhan
ranga.narasimhan
I recently installed acad 2024, VS 2022, ObjectARX wizard 2024.
I created a basic ARX project using the wizard and attempted to compile as it is.
I immediately got this error; #error: /RTCc rejects conformant code, so it is not supported by the C++ Standard Library. Either remove this compiler option, or define _ALLOW_RTCc_IN_STL to suppress this error.
So I changed the following snippet in stdafx.h
to
- Is it OK to do this? Any consequences?? I'll be using MFC later in the project. Also I do dynamic type casting sometimes ;).
- Why in the first place the wizard did not define this?
- And why the (already) commented section did not have _ALLOW_RTCc_IN_STL? See first picture first line.
Thx
tbrammer
1) Yes, it is ok to do so.
2) > Why in the first place the wizard did not define this?
Maybe because you have two options to deal with this:
Either #define _ALLOW_RTCc_IN_STL
Or set the project option C/C++ → Code generation→Check small types   to "No"
For more information about the /RTCc switch see this article.
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
ranga.narasimhan
Thank you @tbrammer .
kerry_w_brown
@tbrammer ,
I had the same issue today with the 2025 wizard ( out of the box )
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
