- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
"errare humanum est" (making errors is human)...
You create a print of multiple parts, and you find out that you have made a mistake on one of the parts. It would be a great time saver if I would be able to "replace" the part. In most cases the fixed part is more or less in the same size as of the part it is replacing.
The current workflow is that I have to remove all instances of the old part
Import the new part
Reorient, duplicate and position it in the same position as of the old parts.
A lot of work...
It would be a much simpler if I can right click on a part and choose "Replace part...". I would be presented with the same exact dialog that I get when adding a part. If there are multiple duplicates of the part I would be promoted whether to replace this single instance or all duplicates. The new part will replace the old part, positioned in the same location and oriented the same as the old part.
Huge time saver.
Hope to see this implemented soon (or even better, if I this option is already available and I missed it...)
Yuval
