Optimization procedure for Topology Optimization in Netfabb Ultimate
Which algorithm is used for Topology Optimization in Netfabb Ultimate 2019 - is it an evolutionary algorithm like Bidirectional Evolutionary Structural Optimization (BESO) or a gradient-based approach?
Andrew.Sartorelli
Hi @Anonymous ,
Optimization Utility for Netfabb is using Autodesk Nastran for the solid model topology optimization. This  solution type in Autodesk Nastran uses SIMP, solid isotropic material with penalization, which is a gradient-based approach. If you want to dig more into the technical details of topology optimization in Autodesk Nastran, I recommend taking a look at the recorded AU course Topology Optimization in Autodesk Nastran In-CAD, co-presented by David Weinberg who is the creator of Autodesk Nastran.
Best Regards,
Andrew
Andrew Sartorelli - Autodesk GmbH
vip23
Observer
Observer
Thank you for elaborating on the algorithm and for sharing the link, Andrew!
