Netfabb Local Simulation error - Simulation not successful.
rajesh.kanna
Autodesk Autodesk
Message 1 of 15
rajesh.kanna
Simulation not successful. Please review Thermal and Mechanical output files to troubleshoot the error. Initially, Analysis toolbar was not found. Even, Mesh preview not working.
We Install Netfabb Local Simulation only.
Replies (14)
Message 2 of 15
steffen_anders_adsk
Autodesk Support
Autodesk Support
Dear @rajesh.kanna,
Welcome to the Netfabb forum!
As the error message advises, please review the thermal and mechanical output files to troubleshoot the issue. They are plaintext, human-readable files that will contain information on what went wrong. Without this review, troubleshooting the issue it will be difficult or even impossible.
Also, please make sure your system meets or exceeds the system requirements.
https://help.autodesk.com/view/NETF/2024/ENU/?guid=GUID-C4E72FE4-9C12-490C-9F4B-5F4ACE2EC179
Kind regards
Steffen
Steffen Anders
Autodesk Netfabb team
Netfabb resources: Online helpSystem requirementsKnowledge baseForumsHomepageYouTube
How to get Netfabb Basic: VideoHelpDownload
Message 3 of 15
rajesh.kanna
Kindly find the result file for your reference.
Report say " restart cache\project_1234_thermal.in\3ED450C5"
Message 4 of 15
steffen_anders_adsk
Autodesk Support
Autodesk Support
Both OUT files state:
Autodesk AM Process Simulation has not been able to acquire a license to run, please contact Autodesk
This is a licensing issue.
Try the following:
  1. Open a command line, and run the command pan without arguments.
  2. This should prompt a new Autodesk login dialog to refresh the login for the solver.
  3. The command line window can then be closed.
Once performed, future attempts to solve from the Netfabb Local Simulation GUI should be successful again.
Steffen Anders
Message 5 of 15
rajesh.kanna
Enter the name of the input file w/o extensions. What should i enter?
Message 6 of 15
steffen_anders_adsk
Autodesk Support
Autodesk Support
Nothing. As instructed earlier, you can close the command prompt without further action and continue working with through the Netfabb Local Simulation GUI again.
Steffen Anders
Message 7 of 15
rajesh.kanna
Error remains the same. Any other solutions.
In My system
In Customer System
last 4 lines are not appeared. Number of Threads , No. of Physical Core and Stacksize.
Message 8 of 15
steffen_anders_adsk
Autodesk Support
Autodesk Support
I will need more detailed information to investigate, including what user and license is involved, which is not a matter for a public forum. I invite the user to come forward through a customer support case.
Steffen Anders
Message 9 of 15
rajesh.kanna
I came to know that you are already following up the customer with case number - [removed]
Kindly Help here to solve.
Mod edit: Removed detail.
Message 10 of 15
rajesh.kanna
Any update on this. Need to solve this asap
Message 11 of 15
steffen_anders_adsk
Autodesk Support
Autodesk Support
Support cases are handled only through the support system; this public forum is not the place to track any status or progress of such cases.
Steffen Anders
Message 12 of 15
1087186
Community Visitor
Community Visitor
I faced the same error regarding the thermal and mechanical outputs. Can you check my project file, please?
Message 13 of 15
mohammad_hazori
Observer
Observer
I have exactly the same problem. For the simulation of the SLM process, I downloaded Netfabb 2025.1. After defining the machine, parameters, and supports, I started the simulation. Then Simulation Utility LT for Netfabb 2025.1 opened. I defined the parameters again. During meshing, I kept getting this error. Can anyone help? Thanks!
Message 14 of 15
jorge_crespoUACEB
Community Visitor
Community Visitor
I am facing the same problem, even with just meshing
Message 15 of 15
steffen_anders_adsk
Autodesk Support
Autodesk Support
For Simulation Utility LT 2025 and 2025.1,
Download and unpack the ZIP archive attached to this message.
Place the contents AdskIdentitySDK.dll and libcurl.dll at <Netfabb installation folder>\SIM\Solver\bin\
Then try again.
Kind regards,
Steffen
Steffen Anders
