Can't export Netfabb file to .cli
tyler_Bortolazzo
Observer Observer
tyler_Bortolazzo
Observer
Observer
Hey, I just nested some parts on Netfabb 2025 and I am trying to export them to a .cli file but I cannot find the prompt/button anywhere. Does it have something to do with licensing?
Sualp.Ozel
What version of Netfabb are you using?
  • Netfabb Basic (free to use without a license)
  • Netfabb Standard (commercial software = requires a license)
  • Netfabb Premium (commercial software = requires a license)
  • Netfabb Ultimate (commercial software = requires a license)
here is our Online help page that compares our features per Netfabb version:
https://help.autodesk.com/view/NETF/2025/ENU/?guid=GUID-E48353B3-E8BE-4D1C-8C2E-E207DAA32CBE
Sualp Ozel, PE
Principal Product Manager
tyler_Bortolazzo
Observer
Observer
Hey I am using Netfabb Premium 2025, I found out it has something to do with adding the correct machine which I am figuring out with the manufacturer. I switched to 2024 and was able to add the correct machine and export as a .cli so it should be good for now. Thank you!
steffen_anders_adsk
Autodesk Support
Autodesk Support
Hello, @tyler_Bortolazzo,
While rolling back to an earlier version may help temporarily with an issue it is usually not what we'd recommend to do. Previous versions are supported and available for download only for so long.
If you could let us know what machine this is about we could have a look why the CLI export is no longer available. It could be a bug that needs fixing, or it could have been an intentional change and that there is now a different preferred way to export.
Best regards,
Steffen
Steffen Anders
Autodesk Netfabb team
Netfabb resources: Online helpSystem requirementsKnowledge baseForumsHomepageYouTube
How to get Netfabb Basic: VideoHelpDownload
tyler_Bortolazzo
Observer
Observer
My apologies, it is not he Max Platform it is just the S-Max Platform.
________________________________
Sent: Wednesday, April 16, 2025 8:32 AM
To: autodesk
Subject: Re: Can't export Netfabb file to .cli
After viewing Netfabb 2025 and 2024, I am trying to add the Exone S-Max Max platform. When I open that in 2025 it states invalid process parameters.
Sent: Wednesday, April 16, 2025 8:24 AM
To: autodesk
The machine I am using is the Exone S-Max. I think the main issue is when trying to add the build platform into Netfabb only 4 build platforms are available, however on the 2024 version I believe there are 9 options available.
Mod edit: sensitive details removed
steffen_anders_adsk
Autodesk Support
Autodesk Support
Ah, I see, thank you for that.
The ExOne engine files and machine workspace for Netfabb are developed directly by ExOne, not Autodesk, and given out separately from the Netfabb installation.
The message "Invalid process parameters." would suggest the engine files either do not match the newer Netfabb or do match but the My machines record you're trying to use is old enough to still reference an engine description given by older files.
Try:
  • Create a new, fresh My machines record using Netfabb 2025 and only use that record with NF 2025. (You could still use the old MM record with NF 2024).
  • If that still doesn't work, contact ExOne, the actual authors of those files, and request newer ones that match NF 2025.
Best regards,
Steffen
Steffen Anders
tyler_Bortolazzo
Observer
Observer
Will do, thank you so much for your help!
