Adding text to slice file
Is it possible to add the layer number text automatically into each slice layer.
Sualp.Ozel
out of curiosity , which technology will this be used for (FFF, SLA, DLP, SLS, SLM... )
Sualp Ozel, PE
Principal Product Manager
Using the slice file to create waterjet traces, but need to have numbers on slices to stack in the right order.
steffen_anders_adsk
Autodesk Support
Autodesk Support
Hello, @Anonymous,
Welcome to the Netfabb forum!
There is currently no built-in way to render text into contours. However, if you have access to Netfabb Ultimate, you could use either a custom EBPA (JavaScript) or Lua to generate contours that help identify the slice number. For example, you could inscribe the number in the form of notches that encode the value in binary, BCD, with a defined distance from a reference point …
Best regards,
Steffen
Steffen Anders
Autodesk Netfabb team
Netfabb resources: Online helpSystem requirementsKnowledge baseForumsHomepageYouTube
How to get Netfabb Basic: VideoHelpDownload
Sualp.Ozel
Your question got us excited about how we can solve it and we think we have a good idea to work the problem.
If you are willing to share your data and collaborate on it send it our way and we can see if we can get you what you are after.
-Sualp Ozel
Sualp Ozel, PE
Sualp.Ozel
Hello
Netfabb Ultimate 2021.1 can now do this thank to your post.
https://blogs.autodesk.com/advanced-manufacturing/2020/12/02/autodesk-netfabb-2021-1-is-now-availabl...
Sualp Ozel, PE
